Championship Rounds, Results and Classes
CHAMPIONSHIP Results - http://www.sauvic.co...hampionship.xls
2012 SAU Club Championship Motorsport Dates (Run by WRX Club of Vic)
Round 1 – Mar 24 Calder
Round 2 – Apr 28 Sandown
Round 3 – June 30 P.I. (AROCA event)
Round 4 – July 21 P.I.
Round 5 - Aug 11 Sandown
Round 6– Sept 1 Winton
Round 7 – Oct 13 H.H.
2012 SAU Vic DECA Dates (Events run by Skylines Australia Vic)
Round 1 – Feb 25
Round 2 – May 5
Round 3 – Sept 8
Round 4 – Dec 8
2012 SAU Track Championship Classes are as follows:
Class A - Modified AWD
Class B - Standard AWD
Class C - Modified RWD
Class D - Standard RWD
Standard Class:
(List of Free Mods allowed in standard class)
Suspension - All
Brakes - All
Electronics (ECU, Boost Controllers) - All
Intercoolers - All
Pods
Wheels Sizes
Modified Classes:
(Any of these Mods will put you into modified class)
- R Spec Tyres / Slicks under a UTQG rating of 120 tread wear (not including 120)
- A stripped interior. Removal of rear seats only is allowed.
- Any other major weight reduction such as fibreglass doors or lexan windows
- Fuel Systems - Any two out of the following three modifications to either: 1.Injectors, 2.Fuel Pump, 3.Non OEM Turbo's, will put you into modified class. (I.E - Only one fuel system mod is allowed)
- non OEM Fuel Pressure Reg
- Non OEM Engine Capacities (GTST with RB26, RB30; GTR with 2.8L, etc)
- Driving a "supercar" (eg. Lamborghini, Ferrari, R35GTR, Porsche 911 Turbo, GT3, GT2, Veyron etc)
- Non OEM Aero
- Slicks are not Permitted in STD or MOD
Slicks include but are not limited to:
Hankook Ventus Z214
Kuhmo Ecsta V710
Hooiser R6
Standard Turbo Clarification
(RWD Standard Class)
RWD Standard can run any Nissan OEM turbo from any RB Skyline.
Highflowing of any of these RB OEM Nissan turbo's is allowed.
(GTR Standard Class)
Any of these turbo's are considered a standard spec replacement turbo and are not considered a turbo mod.
R32, R33, R34 N1's, HKS GT-SS's, Garrett GT2860r-7.
  • Replies 98
Posted Images
Information for Beginners
Personal Requirements
- Safety helmet (AS1698 standard) in good condition (ie. free of dents and scratches).
- Gloves are optional.
- Leather or suede footwear must completely cover the foot and be firmly fitted. No sandals or thongs allowed.
- Driver apparel must cover the body from ankle to neck including up to the wrists. Long sleeved and flame-resistant clothing is mandatory. Wool is best but cotton overalls or trousers and shirts are also suitable. Race-type overalls are not necessary.
Driver Training - Is not absolutely required, but SAU recommends you make your first track day a driver training day. There is a lot to take in and you wont post a quick time on your first outing. Driver training sessions won't be timed and you will only be on the track with other driver training vehicles. You will have the chance to have an instructor with you, this will typically be another club member who has some track experience. Driver training costs slightly less than the normal sprint days (You wont get to compete in the super sprints at the end of the day)
If you choose to 'not' do driver training as your first event, just place yourself in a slow group and spent the first half of the day following slower cars and learning the racing lines before trying to go off on your own and improve times.
Phillip Island Sprints:
You can do driver training at Phillip Island as your first event, and if your instructor believes you are skilled enough he can allow you to participate in sprints after speaking to the clerk of course and making that recomendation.
If Phillip Island is your first 'sprint' event you will need to provide details of an advanced driver training certificate.
Vehicle Requirements
- Fire Extinguisher (AS1841, AS1846 or AS1848, Minimum of 900grams) Securely fastened with a metal bracket and reachable by the driver from the drivers seat.
- Valve Caps (Preferably metal)
- Boot / Cockpit - Must be free from all loose articles
- Headlights - Any forward facing glass must be covered by tape or contact (This only effects R31 and R32's in the Skyline Range)
- Roll Cages - Must be CAMS approved
- Bonnet Catches - All rear-hinged bonnets must have an additional independent non-flexible strap fitted. Permanent straps/pins attached to the bonnet are not necessary. It is acceptable to tie the bonnet down with light rope. Bonnet Pins are also accepted.
R-Spec Tyres Explained
Competition Street Legal Radial's (Dot Approved Semi - Competition)
In other words they are sticky / soft compound
List of known R Spec Tyres - UTQG
Bridgestone Potenza RE11S - 40
Bridgestone Potenza RE55 - 40
Bridgestone Potenza RE520S -
Yokohamma Advan A050 - 40AA
Yokohamma Advan A048 - 60AA
Yokohamma Advan A032R - 60AA
Dunlop D98J
Dunlop D01J
Dunlop D02J
Dunlop D03Z
Dunlop D93J
Toyo Proxes RA1 - 40AA
Toyo Proxes R888 - 50AA
BFG G Force T/A R1 - 0AA
Michelin Pilot Cup - 80AA
Hoosier A3S03/R3S04 - 40AC
Avon Tech R-A
Kumho VictoRacer V700 - 50AA
Kumho Ecsta V700 - 50AA
Pirelli P Zero C
Pirelli P Zero Corsa
Hankook Z209
Hankook Z211
Hankook Z221S
List of soft compound street tyres - UTQG
Federal 595RSR - 140AAA
Kuhmo KU36 - 180AAA
Yokohama Advan Neova AD08 - 180AAA
UTQG = Treadwear, Traction, Temperature
Treadwear - The treadwear grade is a comparative rating based on the wear rate of the tire when tested under controlled conditions on a specified government test track. A tire graded 200 would wear twice as long on the government test course under specified test conditions as one graded 100.
Traction - Traction grades, from highest to lowest, are AA, A, B and C. They represent the tire's ability to stop on wet pavement as measured under controlled conditions on specified government test surfaces of asphalt and concrete.
Traction Grades Asphalt (g force) Concrete (g force)
AA - Above 0.54 - Above 0.41
A - Above 0.47 - Above 0.35
B - Above 0.38 - Above 0.26
C - Less Than 0.38 - Less Than 0.26
Temperature - The temperature grades, from highest to lowest, are A, B and C. These represent the tire's resistance to the generation of heat
Temperature Grades Speeds (in mph)
A - Over 115
B - Between 100 to 115
C - Between 85 to 100
Track Etiquette
Passing
It is the obligation of the passer (faster car) to make the pass. Do not erratically brake or move off the racing line without first signalling to the faster vehicle behind you.
Signaling
If you want a faster vehicle to pass you, signal with a clear hand pointing to the side on which you wish to be passed. If you want them to pass on the left, then signal over the roof of your vehicle. Do not use indicators to signal passing.
Flag Signals
Flags will be used at designated points around the circuits.
yellow_flag.gif The yellow flag signals a situation of danger ahead. Drivers must slow down and show extreme caution. Drivers may not overtake other vehicles until they have passed the green flag.
green_flag.gif All clear signal. It is used at the end of the danger area controlled by yellow flags. Drivers may continue on at race speed.
It can also be used to signal the start of a warm-up lap or practice session.
blue_flag.gif Overtaking signal. The blue flag informs the driver that he is about to overtaken by one or more faster cars. When the flag is waved, it draws the driver’s attention either to the closeness of the car about to overtake him, or to the high speed at which it is approaching. The blue flag can be shown motionless when the faster car is still some distance away but approaching quickly.
red_flag.gif Stopping the race. The red flag will be shown at all posts on the circuit when the Clerk of the Course has decided to stop the race or practice session due to a hazard effecting the course. All drivers must stop racing immediately and proceed to the pit area. Drivers must exercise extreme caution and being prepared to stop if necessary and be aware of the possability of support vehicles on the track.
black_flag.gif Return to the pit area. The black flag is usually shown at the Start / Finish line by the Clerk of Course or his marshal. The flag will be shown whilst your vehicle is being pointed at. This informs the driver they must return to the pit area immediately and report to the Clerk of Course.
checkered_flag.gif Denotes end of session. Use the remaining lap to cool the car and return to the pit area.
Championship Scoring & Points System
Full points for THREE(3) or more people in class
1st Fastest time in Class - 10 Points
2nd Fastest time in Class - 6 Points
3rd Fastest time in Class - 4 Points
4th Fastest time in Class - 3 Points
5th Fastest time in Class - 2 Points
6th Fastest time in Class - 1 Point
7th and below = 0 Points
Partial points for less than THREE(3) people in class (as per note below) **
1st = 6 points
2nd = 4 Points
** There needs to be at least 3 people representing a class in each round for maximum points to be scored, otherwise 1st can only receive a maximum score equal to 2nd place which is 6 Points.
Notes:
1. One championship round is able to be dropped from the score before a total is achieved, this will be the worst scoring round from the entrant, or an event not attended.
DECA Rounds
Each Sub-Event of the Event will be scored individually.
Points will be awarded in order of finishing from highest to lowest as follows:
1st = 50 points,
2nd = 49 points,
3rd = 48 points,
4th = 47 points etc, and so on down to the last competitor.
All points from each sub event are accumulated and a total is created with the highest score winning. Classes are AWD and RWD.
Penalties:
Hit Cone (Make a cone move from it's spot) = +5 Seconds Per Cone
Missed Gate/Cone (Wrong Direction) = No Score - Nil points.
Did Not Finish = No Score - Nil points
Did Not Start = No Score - Nil points
DECA Trophies:
Each round:
– 1st AWD
- 1st 2WD
Championship:
- 1st Outright, 2nd Outright, 3rd Outright.
- 1st AWD, 2nd AWD, 3rd AWD
- 1st 2WD, 2nd 2WD, 3rd 2WD
2012 Motorsport Sponsors
Racepace - Class A - Modified AWD
9/6 Holloway Drive, Bayswater
Ph: (03) 9762 9421
[email protected]
http://www.racepacemotorsport.com/
Pedders South Melbourne - Class B - Standard AWD
131 Market Street South Melbourne 3205
Ph: (03) 9699 4630
Micolour - Class C - Modified RWD
7 Dissik St Cheltenham 3192
Ph: (03) 9555 8011
Driver Dynamics - Class D - Standard RWD
Gate 3, Racecourse Rd, Sandown Raceway, Springvale
Ph: 1300 652 693
[email protected]
http://www.driverdynamics.com//
Import Monster - DECA
Factory 3, 6 Wigan Road, Bayswater 3153
Ph: (03) 9008 0031
http://www.importmonster.com.au/
Martin can you post up an example list of slicks.
Are examples needed, or can we simply judge it visually - for example, this is a slick in my opinion.
So who's in STD AWD other than Joe, Micolour Mick & me?
Not sure if Mick is running many rounds this year either dude?
I don't have the budget or skill to justify running on R-Comps (up against Ant/Chris). So I'm gonna have to aim for consistency in Mod AWD with AD08s due to having -5s :teehee:
Suck it up Roy, if you want to run cheater tyres which are pretty much slicks, then go join AASA sports sedans :P
It makes sense that SAU's motorsport rules stay true to the time attack/club sprints theme of running on semi-slicks or street legal tyres. Having a US DOT rating on the sidewall doesn't make tyres like hoosiers street legal per Victoria's road rules so :nyaanyaa:
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
