  • Replies 478
I'm definitely in, based on what else is needed to fit them... All listings state cars with factory HID's...However, most are removed for compliance.. If it's pretty straight forward to get these working... im in for a BLACK HOUSING set.. 2003 Coupe
^^^ incorrect. Despite the fact that Aus compliance states that ALL factory HIDs without self-levelling and self-washing facilities need to be removed to meet ADRs, when I was shoppping for a V35 I couldn't find one without HIDs! I think there are WAY more with HIDs than without.
But if you buy an aftermarket HID kit which are as cheap as $200 now you could fit them into these new lights with basic meachnical/auto electrical skills. You only need to modify a couple of wires, and install a power wire to the battery on a relay. I did it on my S15 and R34 - pretty easy job!
the seller said Zenki (early) and Kouki (late) models are both ok.
Confirmed List:
Chrome housing:
1. 4evershiva
2. 81gSKy y
3.Nightcrawler
4. Thinktea
Black housing:
1.Dreadnought
2.Megahowler
3.Runner4life
Edited by shiva
Confirmed List:
Chrome housing:
1. 4evershiva
2. 81gSKy y
3.Nightcrawler
4. Thinktea
Black housing:
1.Dreadnought
2.Megahowler
3.Runner4life
DO you have a pic of the back of these lights? im curious if the have the factor HID hole that fits the ballast and then you run the wires through the headlights and then use the HID bulb??
See the below pic, look at the area above the white box, thats where the factory HID ballast goes..
http://www.sabersport.com/Merchant2/images/headlight/02-AZ-IG03-PCC-HID-RF-2D-02.jpg
my car has hid lights, couldnt tell you if they are factory. they where there when i bought it. im not the first owner in aust. but if they will work with any hid's ill def be in for a chrome set. thanks
hey Sheldon, can you give a plain and simple answer so everyone's question can be answered.......i know you had some trouble to get the LHD to RHD in your lights but apart from that is it a big deal to get the lights fixed into the car with RHD specifications and is it legal?
Jesse's Payment options:Direct your enquiries to [email protected]
for a larger order like this an international transfer will work out a
little cheaper.
bank charges and options are as follows.
Paypal <- will be instant and you have buyer protection, Im also
protected from exchange rate changes as I can send you the bill in
JPY. Has a 4% fee and they dont give the advertised exchange rate ,
works out the most expensive way to transfer money.
Local transfer in AUD to my NAB account <-this has no buyer
protection, Im open to exchange rate changes so can be burnt if the
AUD takes a quick dive. no straight fees but the rate they give is
~3.3yen down on the advertised exchange rate. This is how I do most
of my transfers from Aus due to ease of transfer for the customer and
cheaper rates than Paypal.
International Transfer <- slow, a little complicated for you to send
money, takes a week for the money to clear into my Japanese account.
No buyer protection. They will give the advertised exchange rate and
as the money can be sent in JPY Im safe from exchange rate changes.
They do have large flat fees though, depending on the bank you use
on your side fees range from $0 to $25 and then there is an additional
4000yen receiving fee on my side. This kind of transfer only works
well with transfers over ~$1500 worth (this is how most car exporters
move money around)
Im ok with any of those ways so which ever suits you is ok.
*Ill only need the purchase cost of the tail lights up front and will
charge my commission and shipping costs after they have reached me and
have been weighed up.
Jayce - I Have aftermarket headlights from U.S
I have attached the link below.
Took me and A mate about 5 hours - hard bit is getting front bumper off. But second time its simple with practice. Sock might be easier - have the nismo one.
Post me with any questions mate.
3470-projector-headlights.asp&docid=vCQhRAQNqisyRM&imgurl=http://www.slickcar.com/products/LHP-G35032JM-TM9241885E-02.jpg&w=750&h=750&ei=-PVXT8b3OuyhmQW4m-DADw&zoom=1&iact=hc&vpx=610&vpy=193&dur=234&hovh=225&hovw=225&tx=95&ty=153&sig=110179230568841931979&page=1&tbnh=142&tbnw=142&start=0&ndsp=22&ved=1t:429,r:13,s:0&biw=1151&bih=786
little cheaper.
move money around)
I should allaborate a bit on my previous post - for everyones benefit.
Long story short;
- Factory HID's - Fitted straight into my Headlights from the U.S. They sit perfectly in the aftermarket metal clip and the ballast screws to the bottom - per stock set up.
- Yes - you can do it yourself - there is no wiring required - unless you want to light up the Halo's (I only have the LED sttip). In which case - Cut wire and solder it in. The front bumper needs to be removed. give yourself 5 hours or so if you havent dont this before from start to finish.
- NO they will not be legal. However - most workshops will give you a roadworthy but just notify you that if you're asked to take them out due to defect - do it.
- The lights will not point correctly immediateley after install.... you will need to spend time toggling the left and right / up and down screws in the back of the lights. You need to understand where the stock set up points - so you can adjust accordingly. Test this about 15M from a wall and If possible mark on the wall where the stock set up sits. On the V series you will notice the left light points slightly higher and to the side of the road. The right hand light (the one that will shine in traffic's eyes) needs to be put as low and straight as practically possible. This can alleviate some of the problems with no self leveling.
If anyone needs tips, Im happy to help out. Done the job on two cars now....and I work in Bank - so any one can do it!
Cheers
Thanks for the info dude but we are planning on getting these from japan, which should be RHD compliant, so we dont have to fiddle with the light settings.......
Long story short;
Cheers
*** Light comes on in Brain***
My bad - yes i see that now! Best of luck with it.
I can recommend importmonster.com.au in that case. Lots of OEM bits.
Cheers
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
