  • Replies 478
Confirmed List:
Chrome housing:
1. 4evershiva
2. 81gSKy y
3.Nightcrawler
4. Thinktea
5.Dog with Bone
6. Heretical
7. interfooler
8. bigdr33gtst
Black housing:
1.Dreadnought
2.Megahowler
3.Runner4life
4.Mayo_85
Hi Paul, could you please read the entire thread to get an idea,
Hey guys now could you please put your location next to your name so we can pair each other for a common delivery for 2 pairs of headlights....
Edited by shiva
Confirmed List:
Chrome housing:
1. 4evershiva
2. 81gSKy y
3.Nightcrawler
4. Thinktea
5.Dog with Bone
6. Heretical
7. interfooler
8. bigdr33gtst
Black housing:
1.Dreadnought
2.Megahowler Melbourne VICTORIA
3.Runner4life
4.Mayo_85
Confirmed List:
Chrome housing:
1. 4evershiva
2. 81gSKy y
3.Nightcrawler SOUTH AUSTRALIA
4. Thinktea
5.Dog with Bone
6. Heretical Adelaide SOUTH AUSTRALIA
7. interfooler
8. bigdr33gtst
Black housing:
1.Dreadnought
3.Runner4life
4.Mayo_85
Confirmed List:
Chrome housing:
1. 4evershiva
2. 81gSKy Melbourne VIC (paired with Thinktea)
3.Nightcrawler
4. Thinktea Melbourne VIC (paired with 81gSKy)
5.Dog with Bone
7. interfooler Melbourne VIC
8. bigdr33gtst
Black housing:
1.Dreadnought Melbourne VIC
3.Runner4life
4.Mayo_85 Geelong VIC
Confirmed List:
Chrome housing:
1. 4evershiva
3.Nightcrawler
5.Dog with Bone
8. bigdr33gtst Fremantle Western Australia
Black housing:
3.Runner4life
Confirmed List:
Chrome housing:
1. 4evershiva
3.Nightcrawler
5.Dog with Bone - Adelaide SA
Black housing:
3.Runner4life
Edited by Dog with Bone
Confirmed List:
Chrome :
1. Nightcrawler & Heretical
2. Thinktea & 81gsky
3. Dog with bone - adelaide
4. 4evershiva
5. bigdr33gtst - WA
Black housing:
1. Dreadnought & Megahowler
2. interfooler(CHROME) & Mayo_85(GEELONG)
3. Runner4life
Payment options: i Have sent an email to jesse streeter regarding the purchase and will send a list of people once we have compiled it........I would prefer you guys to organise within urself and make payments directly to Jesse......contact him on [email protected]
Read the previous comments for the payment options,
P.S: unable to cut and copy options due to html failure in my laptop...
Edited by shiva
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
