umm google can answer this one too....
do a search on google for 'vl turbo on rb25/30'
http://www.skylinesaustralia.com/forums/topic/390704-std-vl-turbo-on-rb2530/
iGoogle
and they said the VL turbo sucked, even a highflowed version....
modifi-able
VL'swastegate is in side dump pipe. Rb25det's are in the turbine housing. only way to fit it is using the VL's dump pipe and modify 25's front pipe to fit. nothing on the comp side would match up either. Going to be hell lot of modifications.
who has done this? and what kind of power did you get?
compared to a intercooled rb30et what was the power like? thanks
talk to the boys on calaisturbo your best bet tho is a aftermarket turbo no point doing a 25/30 and using a stock turbo waste of time in my eyes
    • This sounds like someone who would have owned an R33 in their past... It's okay, I'm 100% picking up what you're putting down Mark.
    • Just back on what was raised about jacking off the the tow/tie down point on the front of cars. I've used it plenty. I've also watched it on a car where you could see it move the front end of the car. It was like the front end/whole car being tweaked and twisted a bit. I will say, I struggle to find good jacking points on MOST cars. The ones that have good points, I then normally struggle to find a jack tall enough to make the car change height!   One of my go to points for either the jack, or the axel stands though, is either a suspension pickup point, OR a subframe to chassis major bolting point. I actually think its the subframe on my R33 that has a bit of a bend in it, from being jacked in the middle too. However, it could have been one of my many other cars I've had over the years! Or it could also be the from me jacking it up, and the fact the top of the front radiator support isn't there, so it can allow the front of the car to move and bend etc.
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
