  • Replies 111
Don't worry I agree wholeheartedly - to be able to win on street tyres in a virtually unmodified car there has to be cheating going on. Some consistency / conservative driving, but lots of cheating!
I just dread the day I get behind a RWD and you all get to really see how much I suck at driving!! Going to be like starting from scratch.
Dont have excel @ home... anyone enlighten on how bad my fail was? :)
I wouldn't class 8th Overall as a fail Ash! :thumbsup:
So I did some shuffling around with excel...
If I exclude results from the events that I didn't run (only half the events thanks to my radiator), I then come from 37th up to 22nd overall.
Then if I go one step further and look at just RWD, I finished 11th out of 30... Sounds good to me! :laugh:
Oh, and who was on the clock for battle 1... Apparently I pulled a 29 second run on my first battle???
(although means nothing coz I nudged the cone in the finishing box!)
Bring on round 2 already!!!!!!
Thanks dude :thumbsup:
I'll class that as a reasonable, still fail though. Trying to do better than 3rd AWD this year and epic diff fail hurt me :D
Loving the mega mini wang though. More I think about it the more fun it was.
Half because it was new, half because its quite challenging compared to the other events. Sooo much gravel
The 0 points for a WD really hurts now, still 11th is my best result yet, thank you twin turbos :worship:. still plenty of improvement possible, looks like i still need to show a bit more commitment on the wangs.
congrats to the winners :thumbsup:
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
