I wouldnt use standard sticky / duct / electrical tape, your right - that wouldnt do anything.
However in the picture I found on google, that looks like cloth tape to me.
It's 3m blue painters masking tape. All the ricers use it because it doesn't leave any residue behind and they think it looks cool
I use it for masking off panels when polishing
Reality is clear sticky tape would offer more resistance - simple test, try pushing a ball point through plastic based sticky tape vs paper based masking tape
Edited by domino_z
Yeah judging by the colour, it probably is that 3M tape actually, now you mention it.
Thats the same tape I use when polishing. Very thin - wouldnt do sh*t for your bumpers!
So how does a bidding war work?
Did you deal with the people bidding or with the owner, because i sure as hell wouldnt trust myself from getting greedy when selling a car if i had more than buyer interested :)
I'm not suggesting that a war happened in your case ossie but could not a seller co-opt the help of a phantom bidder when a seller advertises "bids over such & such"?
Easy to do?
Congrats on a sensational motor vehicle - one of the world's best!
Wrong.
Congrats on your purchase. Definitely a good a buy with those KLM's if the car is immaculate. Thanks for letting us know what you paid too, certainly is a very helpful guide. When you look at some of the other cars there for sale, they really are dreaming for what they're asking. As has been said before on this forum 'the market decides'.
Congrats on the purchase,
But for those taping up their cars to stop chips etc... for the love of god, at least get it done using a decent product.
Yes it costs a little more than a roll or 2 of tape, but you can barely see it for one, and it should last for years, and WILL actually stop stone chips, and even minor scratches/scrapes.
We use 3M scotchguard paint protection film. See below. (FYI this image isn't my own)
  • 3 months later...
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
