hey guys, about to start ordering body parts for my build but i cant decide on a colour!
car will basically look like this
the factory wine red has really grown on me. but im not looking for any outlandish "LOOK AT ME" colours
so, open to suggestions!
kgo!
https://www.sau.com.au/forums/topic/393733-help-me-choose-a-colour/
