Hi All,
I was very excited about this new Iphone app called dynolicious. Unfortunately for me I only have an ipad (with some difficulty holding it vertical weged between the center console and some misc items - :) umbrella works well actually) so I used that instead and this is what I got after quite a bit of fooling around and some testing.
settings were: 1450kg , drive train loss 25%, roll-out 1inch (how sensitive is a real drag strip - i.e before it senses your reaction time vs star time), dollout distance (12 inches - default value - is this an unfair start?) (trigger 0.1G)
Car is a stock r34gtt auto - would up the boost to about 14 psi - no other mods.
Is this G of 0.65 accurate - can anybody confirm?
How would a similar car with manual trans perform?
What should I expect from an IC & 3 inch exhaust, should I also do fuel pump and EBC.
My only complaint is that I think the Kw are out of whack, I was expecting around 230kw. Has anybody else tried dynolicous and if so what settings have you used.
I think its pretty much on the money as I did a 14.71 quarter at a real drag strip with the same set-up.
<br class="Apple-interchange-newline">0-10 km/h:0.67 sec0-20 km/h:1.25 sec0-30 km/h:1.82 sec0-40 km/h:2.34 sec0-50 km/h:2.94 sec0-60 km/h:3.57 sec0-70 km/h:4.24 sec0-80 km/h:4.97 sec0-90 km/h:5.73 sec0-100 km/h:6.51 sec0-110 km/h:7.39 sec0-120 km/h:8.49 sec0-130 km/h:9.75 sec0-140 km/h:11.07 sec0-150 km/h:12.47 sec0-160 km/h:14.02 sec
Elapsed Time
60':2.73 [email protected] km/h330':6.59 [email protected] km/h1/8 mi:9.68 [email protected] km/h1000':12.34 [email protected] km/h1/4 mi:14.57 [email protected] km/h<br class="Apple-interchange-newline">
Max Speed:164.0 km/hMax Acceleration:0.65 G'sPeak Horsepower:207 kW<br class="Apple-interchange-newline">
https://www.sau.com.au/forums/topic/394065-anybody-used-dynolicious/
The point was that Dynolicious and similar software is fairly accurate and if there was anyone out there that has used it.
Most of the replies so far strike as either young and immature or just immature.<br class="Apple-interchange-newline">
Your approach to testing the power of your car strikes me as childish. I can go and say, "I dyno'd my car yesterday with my Iphone, got 300kw, fck yeh (self hi 5)"
Or
"Went and got my car dyno'd today at blahblah, car pulled a good 300kw with nice power curve and AFR's, boost was steady, car's looking pretty good"
Which phrase do you prefer?! Or do you prefer peak power reading other than power curve? I know which one wins races.
Edited by eat_me
i think what would be cool is if the car dynod 200kw and the app showed 200kw, i would be impressed. more so if it was consistently accurate against lots of cars. that would be really cool.
but using it to determine how much power your car has, instead of being impressed with what an iphone can do, a liiiiitte silly.
one day im sure this technology will totally be possible. but right now i dont think we should fuss over the very first sign of such a thing :)
P.S. 206kw for your described setup is probably a little overstated. Maybe at the flywheel.
I've got a copy of it but never have really been able to test it properly :(
The app to be accurate needs to be mounted with a good mount, otherwise movement completely throws off the calculation.
One friend claimed reasonable results with it, I'm skeptical.
To actually use it 0-100 or 1/4 mile you need to be in a straight line and start from a dead stop. On freeways you can't exactly stop so I've never done 0-100 properly :)
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
