thanks sinno!
yeah like i said though, if it was just the pale blue colour it would be fine, with more pics i can see how much of a dogs breakfast it is. Looks super quick but going on looks alone it needs some cleaning up..
  • Replies 192
^big lulz^ first time I have seen this.
I wish I knew this song ~~~~~~~~ as it's happend to me after a long stint on excercise and came back for furlough.
It woulda been less embarrising to Kim the chick I was with :P if I'd started with the chorus.
HARD time explaining I wasnt "able". Just give me 30 mins will ya - :laugh:
if I am reading this right, are u referring to blue balls :)
You can save yourself some cash and grab a wallpaper here :)
MATBOY'S WALLPAPERS
If you wanted an actual print for a wall send me a pm with what size you'd be after.
Thanks Matt!
Just wanted it for my desktop background. But seeing your work, I'll be definitely purchasing some prints!
Awesome pic...man, how fugly is the r30 and r31 - really though, they are not gtr's hence doesn't even qualify in my books
DR30 RS' and HR31 GTS-R's will always be cooler than any 90's GTR
and better looking
Mid 80's styling ftw!
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
