This must be a common thing on 'line boxes....
had my clutch replaced when i bought the car, so unsure if it did it before that, but the stick just catches a little as you throw through ffrom 2/3 and 3/4 - seems funny that my box should go, as it's on an NA 2litre - bought with little mods, so unlikely to be raced much.
So im thinkin that maybe all our gear boxes must just be wearing - maybe synchros not aligning properly ? ive done 195k if that means anything.... how bout you guys, lot of kays ?
https://www.sau.com.au/forums/topic/39486-r33-gearbox-ed/#findComment-802555
yeah, worn synchros = quite common, chuck in redline lightweight oil and the problem magically disappears :rofl:
as Duncan mentioned this is a common occurance with these boxes and your not the only one to have this problem.
Just get some high quality Gearbox oil and it'll gradually get better. Redline Shockproof Lightweight is the best stuff to use IMHO.
https://www.sau.com.au/forums/topic/39486-r33-gearbox-ed/#findComment-802738
This is pretty much how it goes, if Redline Shockproof can’t fix your synchro problems then you will have trouble finding something that will IMHO… apart from getting the synchros replaced / gearbox re-built. Its your best (relatively cheap) bet to fix this problem.
https://www.sau.com.au/forums/topic/39486-r33-gearbox-ed/#findComment-806710
    • Hi, wondering if the HKS bar and water reservoir still available? Thanks
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
