I currently have an R34 gtr with some 18x10 +12 lmgt4 copies pictured below. Im consdiering some 18x10.5 work meister S1 3 pieces in an offset of my choice (thinking +5 or +8 maybe. Just wondering on peoples thoughts on how these would go with my car. The colours I would look at is silver with polished lip or black centre with polished lip. I wuold be getting the R disk which is deep dish. The car will be getting nismo side skirts, rear pods, z tune front bar and carbon wing blade shortly.
Even if there are any photoshop gurus that could help.
https://www.sau.com.au/forums/topic/395036-r34-gtr-with-work-meisters-s1/
  • Replies 61
Posted Images
Yes do it.
If you do go +5 or something, i'd love to try them on my car :D
10.5 +12 just doesn't cut it.
These are ssr but similar enough to give idea:
Someone has them for sale on here.
http://www.skylinesaustralia.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=382594
No do not do it. LMGT4's on a R34 GTR look great...do not change the look.
They aren't legit LMGT4s.
Black centre with polished lip, do it! I reckon it would look sweet if you did the side skirt extensions / rear pods in carbon fibre too (like Terry's white N1)
Yes do it.
http://www.skylinesa...ttach_id=382594
Woah, that car looks hot! Got any more pics/link to for sale thread for wheels?
Cheers
I think 18" will look to small against the car. Might have to go 19s lol
Also looked at the sizing chart and the only way to do a +5 offset is with an 11" wide rim, I wouldnt like to stretch 265s that far lol.
adamskill...its called having a job and working hard, im just reaping my rewards
just be happy with owning a 34 gtr you ass hole.
This ^^
Why don't you look into other slightly more original wheels? Meisters and SSR SP1's are so common and boring now... but of course all the little fanboys will have a reply to this
No, you can run +3 and +6 on rear and front respectivelly on 11", with unrolled guards and quite lowered with 275's, no issues.
This ^^
probably cos they look hawt...
jus sayin
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
