Alloy Wheel Repair
StevenCJR31
 Share
Hi guys, can anybody give me a location (preferably NOR ) for alloy rim repairs?(i know i can google but would prefer a business that someone here can vouch for) i have some gutter rash on my 34 GT-t sedan and it would really tidy it up if i got the rash fixed, also the car has the HICAS rear steering, where is the resouvoir for checking the fluid level, i thought it would be in the boot but im stuffed if i can find it and i dont want to damage the boot trim looking for it. any help appreciated thankyou
  • 9 months later...
does anyone know if you can get the holes where the studs go through repaired. i recently had some studs break and the holes are now ovals
^^`suggest you turf the rims if they are stockers
took the rims to alliance: the owner suggested i fix the rim rash with body filler and yes he was serious ( as well as being completely uninterested) so i reckon i will give briffa engineering a shot
Edited by StevenCJR31
 Share
    • I have an R34 GT that had a turbo added. It runs for a couple of mins then the engine just cuts out.  And requires pumping the throttle to start it back up. I unplugged the MAF and it runs without cutting out at all although the AFR is all over the place. I have replaced the MAF but am back to my original issue.
    • Right. Of course i knew the turbo inlet is sucking air. Just testing you.
    • Im re-inventing the wheel lol
    • Issue resolved.  So I was driving a couple weeks ago and noticed everytime I got on or off the highway (long right hand turns) the car would bog for a second and then pick back up. Decided then to just change the fuel pump.  In doing so when I pulled out the fuel pump I noticed that the fuel strainer was very dirty on the bottom. Additionally, there was a little rust in the tank. The fuel strainer was only partially seated on the bottom of the pump which I was surprised to see was an AEM 340. I removed the fuel filter and it was clean coming out the out end and straight rust water coming out of the feed side.  I changed the fuel filter and replaced the fuel pump. While I was there I went ahead and installed radium studs in the fuel hat and rewired the fuel pump with the relay mod, correctly this time. Used 12ga straight from the battery with a 20amp relay and inline fuse.  Car feels much better. Only thing I have left to get it up to par is replacing the exhaust gasket and installing new exhaust mani studs to fix the missing one and the broken one. Once I do that I'll be investing in some data logging equipment. Looking forward to enjoying this 32 this summer. Wanted to thank all of you guys for all of your help and post the fix in case anyone is dealing with a similar issue.
