Good gearbox with no know issues: Royal Purple Syncromax, Redline MT90, Motul Gear 300 (most expensive)
Good gearbox with minor crunch issue: Redline Shockproof Lightweight (very popular, I use it myself)
Rooted gearbox: Redline Shockproof Heavyweight
I'm not sure about Castrol to be honest, I've read people dropping their current oil for Castrol and it was worse than the old oil (some even putting the old oil back in)
my synchro's are pretty "chunky". going into 4th now sometimes grinds. sometimes i go to grab 3rd from 2nd and it gets jammed in the middle somewhere.. only when i go from 2nd to 3rd though.
should i try heavyweight first or lightweight?
also does anyone know how many litres you need? (manual 25 box)
Thanks.
I don't know about you guys, but i see the redline oil as a really expensive bandaid fix. By the sounds of it, all you's are really doing is hiding the fact that your gearbox is f**ked. I would rather spend what the redline oil costs on a rebuild kit/or a workshop rebuild if you don't know what you're doing. If the box was operating well it wouldn't matter what brand you used as long as it was the right grade.
  • 1 year later...
  • 3 months later...
  • 5 months later...
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
