Bought a major part of the project today. Everything from now on should fall into place
Give Scott a buzz for the headlights and whatever else you need.....he has a whole wreck down in Mexico!
Damn.....his an hour away....was going to offer my services! I really like this project.....just needs a supercharger as well! :P
Only an hour mate.....and in your stagea it shouldnt take too long. I will take that bar on tuesday can not find a white one cheap ebough so ill have to buy your black one and paint it.
So I'm assuming you don't need photos of mine anymore then?
Hope everything goes all right with the "big bill" you received; guess it wasn't that big after all eh?
Why would you tell me a bullshit story if you had no intention of buying my bar; especially since I offered to go out of my way to show it to you when you said you were coming down for WTAC? And if you knew you weren't going to buy it; why would you ask me to email you photos of it this morning?
I'd rather you'd been honest with me; and told me it was more than you wanted to pay, or that you were going another way, and we could have left it at that.
We're all adults; why lie?
I spend a lot of time helping people out; and I'm happy to do it, but dreamers like you wasting my time is not something I enjoy.
Don't bother PM'ing me again about the brace; I don't need your money.
Cheers Dale.
Edited by Daleo
I was looking at other bars in white. The bill arrived but i dont have to pay it for a month or so. I bought a non turbo stagea radiator fron mount.
I couldnt find any bars in white for the $150 price your asking. I get paid again on tuesday and i thibk i have your account details and youll get the money tuesday afternoon.
I bought the radiator mount instead of going to time attack. Thought i would get better use out of the radiator mount than time attack.
I was looking at other bars in white. The bill arrived but i dont have to pay it for a month or so. I bought a non turbo stagea radiator fron mount. I couldnt find any bars in white for the $150 price your asking. I get paid again on tuesday and i thibk i have your account details and youll get the money tuesday afternoon. I bought the radiator mount instead of going to time attack. Thought i would get better use out of the radiator mount than time attack.
The front bar was $180, the brace was $150.
I don't understand; do you want to buy the brace or the bar or neither? Your above post implies that you're buying a front bar from Jetwreck; but you've sent me a message asking for pics of my front bar.
So which is it?
Edit; Sorted, thanks Mark.
Edited by Daleo
Huh....I'm confused...yet again! :)
I'm not selling anything.....I just mentioned if I lived closer I'd give him a hand as I think it's a valid project..... I'll do anything to help rid the would of that butt ugly v35 front end! :P
http://forum.jdmstyletuning.com/showthread.php?17111-The-Stagea-thread/page3
Ok there is some nice older stageas but scroll down and youll see a whote M35 2with a series two V35 nose...... Looks hideous on the wagon
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
