  • Replies 51
Hi Andrew
What was the final cost with fitting and all electrics?
Look forward to seeing a picture of the back of the car. I might take mine to him soon if i can afford it.
Cheers
Chris
Basicly it has no load rating. He just said it would be good for 2000kg and 150 on the ball.
Ill try get some pics of it but I really need to take the bar of to get any deceint ones. It does look a bit better than the Fast fit one tho
I'd be interested to see it. If it's rated to 2000kg; there should definitely be some visible structure under the boot area, otherwise it's not really going to be much better than the Fastfit bar.
  • 9 months later...
I am going to go see the guy at Locset over the weekend in Ringwood. He has advised that he can do the job for me but it has been a little while since he has done one for a stagea.
Lets see what he can do and would be interested to see what price and what setup he will build for me. :yes:
I presume it will be a similar setup to what you guys have above and will be used to tow the race car!!
That's who done mine. Ive towed my HQ a few times with it. 2000kg all up. 1300kg car 700kg trailer. On flat roads it struggles so never took it to far, only around 30km from home. Fuel economy went through the roof in that short distance. It also wore the inside edge of the rear tyres funny.
Ive brought a F350 tow truck to tow it now, just in the process of putting it on club reg.
Hi dasic1
I have just updated from a R31 skyline wagon to my C34 stagea rs4s. But i am towing a mazda RX3 so not as much weight as your 'Q'. I am hoping that it will tow well considering my total weight with race car and trailer being more like 1400KG to 1500KG max.
I presume that the Guy in Ringwood will still be able to help me out and it doesnt matter what model stagea it is? He seems to be able to custom build what ever you need from talking to him on the phone. But time will tell when he see's my car and I see the quality of his work. My one concern is from a engineering perspective and i want to know where the mounting points are going to be put on the body chassis rails of the stagea. :unsure:
All tee'd - up for next week after seeing Locsed on the weekend. He will do a 2000kg rated towbar as per our discussion on weekend unless something unforseen comes up for C34 stagea. He will have to cut the bumper but it will be a small neat square hole as the car is already lowered and i need the height to be correct for the towball.
I said to him that it had to nice a neat and i dont want electric's handing out on the bumper, they will be in the boot and i will pull them out of spare wheel well when i need to plug in the trailer.
:rolleyes:
:rolleyes:
PLEASE keep us updated on this.
I'm very keen.
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
