hey guys i looked under the car today ( have not driven it for about 6 months) and noticed a 50cent size oil patch on ground just under the bell housing however when you look to the back of the box near the drain plug yu can see where oil is about to drip but it also seems to be going to the back of the box also but not dripping onto ground. i cant seem to find where it is exactly coming from and it is deceiving. is this a common problem could the drain plug just be leaking as it is still tight. or is it something more serious like rear seal or input shaft seal
https://www.sau.com.au/forums/topic/395762-deceiving-gearbox-leak/
Did you smell the oil? It could be engine or gb oil.
+1, and the reason this is being suggested is that the rear main seal (rear of block to crankshaft) can leak engine oil out at the bellhousing.
found the leak thanks guys one of the rear housing bolts to the box was a little loose and was leaking and the leak towards the front is actually my exhaust side cam cover leaking down the back of the motor
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
