Hey guys,
Doing research on cars because I will be buying my first one towards the end of this year. I love both the R34 Skyline and S15 Silvia and I have heard good and bad about both but which one do you prefer and why? Also which engine is easiest to squeeze more power out of?
Cheers, Tristan.
P.S. Being my first car will be N/A
https://www.sau.com.au/forums/topic/395774-s15-vs-r34/
  • Replies 138
Posted Images
R34 is going to be heavier for a start. The S15 if it was an Autech one would be my choice, greater range of parts to get the best out of it easily. IMO it wouldnt be worth spending any money trying to make them faster, as ultimatly you probably plan to turbo it when allowed right? So why waste money. Get the most out of the chassis first.
https://www.sau.com.au/forums/topic/395774-s15-vs-r34/#findComment-6288079
if it was me.... For a N/A Id go a Autech S15 forsure and dont do much to it , keep it nice and simple then when it comes time to sell you can make your money back and buy something turbo then take the power from there.
https://www.sau.com.au/forums/topic/395774-s15-vs-r34/#findComment-6288104
A KE55 corolla and save your cash until you're allowed a turbo car.
Otherwise they are both puss, so buy whichever one you like the look of best because neither are performance cars and both are pretty much the same in terms of reliability.
https://www.sau.com.au/forums/topic/395774-s15-vs-r34/#findComment-6288665
If i HAD to choose between the two, then id ho Autech S15.
But if it wasnt a definite choice, i would definitely go for a Honda of the same era. Dont know what they cost over your way, but a DC2/5R would be quicker than both of them without much trouble.
Billions of aftermarket/new parts for modding and maintenance.
Or a H22a/K20a Euro Accord if you want something a bit bigger.
https://www.sau.com.au/forums/topic/395774-s15-vs-r34/#findComment-6288845
ive owned both S15 and r34 (both turbo though) and i'd have to day the r34 feels more solid and sticks better but i do miss the go-kart feel of the S15 sometimes. Go the Autech S15 is you HAVE to have an import now, otherwise save your cash monay for when you can drive a turbo.
https://www.sau.com.au/forums/topic/395774-s15-vs-r34/#findComment-6288850
http://www.my105.com/ListingDetails/tabid/65/p/1/cid/522/id/4769/Default.aspx
This will blow NA R34's and S15's away at all tracks, doubly so on the gravel. It's already caged so you can go to the track and let loose..
Guaranteed the most fun you can have with your pants on :thumbsup:
Probably not good for P plate laws - would have to check on that.
https://www.sau.com.au/forums/topic/395774-s15-vs-r34/#findComment-6296242
I just don't get P platers and insisting on skylines or silvias etc.
take the blinkers off your eyes mate.
go have a drive in a Renault Sport Clio 172.
1050kg
124kw
leather bolstered seats
xenon head lights
throw it in to a corner or 2 and see if you an even remember what a non turbo skyline or silvia is.
that is just one example of many good cars for P platers.
Unless you want to pose.. then my post is of no use to you.
https://www.sau.com.au/forums/topic/395774-s15-vs-r34/#findComment-6296690
Both will be horrendously slow and get beaten by the new v6 commodores and falcons and you will merely just be a "poser" with a Skyline or Silvia badge. My advice is save your money and upgrade once you get your full licence
So we are posers for owning a non turbo, learn your skyline history it didnt start off with Turbos going shutututu and AWD, they were naturally aspirated wasnt till the 3rd-4th that turbo was introduced, the Hakosuka 2000GTR the real start of the GTR brand was a Naturally aspirated car if i had a choice out of any Skyline it will be the Hakosuka. If i had a GTR badge on my 25GT then i will be a GTR poser, but you cant accuse it of being a Skyline Poser because it does not meet your narrow minded perspective of the Skyline brand name.
Edited by starwarz
https://www.sau.com.au/forums/topic/395774-s15-vs-r34/#findComment-6297010
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
