Okay I know I am gonna get flamed for this but I jumped the gun on my project and began scrapping the exterior engine items and also in so doing while trying to get to the oil pump I had to remove my timing belt and crank gear. Problem now is that I did not set the cam gears to the markers and the crank appropriately. Any advice as I cannot say for certain that the crank is at the same position since I removed it, it is definitely not been turned more than a couple of teether on the flywheel side so what are my options? Will it be necessary to remove the head and ensure that cylinder 1 is a TDC and then ensure that the cam gears are at the markers before torquing it back or can I do something else to get everything back where it should be? I currently have the sump off so was wondering if I can somehow turn the crank and manually turn the gears to get it set or should I just swap back on the front crank gear without the oil pump and rotate the entire assembly until it is at the markers? Any advice is greatly appreciated, yes I know I made a huge mistake but need to correct it. I have parts on order for the engine so I am waiting for those to be shipped in, gasket kit, adjustable gears, tensioner stud, water hard tubes, tensioner and idler pullies, new timing belt, coolant and vacuum lines etc so wanted to get things prepped for assembly.
https://www.sau.com.au/forums/topic/396159-problem-timing-belt-advice/
If you removed the spark plugs, turned it by hand, would you cause damage if it hit the valves?
probably not...
usually you could put a big socket extension down cyl 1 spark plug tube, you'll see it move up and down when you turn the engine and be able to tell where tdc is, then the belt will only sit over one tooth with perfect TDC.
At worst you could take the cams out so there'll be no valve interference if you need to turn just the crank- easier than removing the head. Then put it all back together in the right position when you get the new gear. The valves can also interfere with each other if you spin the cams individually, and you will get piston and valve interference with valves that are open if you just spin the crank, not worth risking any damage.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
