After 4 years of slowly gathering parts for my rb26 im finally putting her back together(spun bearings) 4 years is a long time and cannot remember for the life of me where the hell these go!!they where in the same zip lock bag the 3 bolts for the lower front cover was in but cant see them being used for the front cover, hope some one can reconize these 2 sleeves i guess you would call them? and save me having to pull the motor apart again!
https://www.sau.com.au/forums/topic/396336-where-do-these-go/
The head to block use a dowel pin, I'm thinking they must be for one of the front covers because of the zip lock bag i had them in I've tried Nissan fast program to try and locate them but still come up with nothing
if you used an arp stud kit you may have just been able to align the head without the dowels on there and not noticed that you needed them, if the engines out of the car and easy to rip the head off then id just do that to be sure, althought they could also be dowels from the box to the motor
The motor is still on the engine stand, I prob used the stud kit as alignment and not thought twice, the r33 engine manual has no mention of there being locating dowels which is why I may have over looked it, guess what I'm doing this weekend then god damn it!!, unless you guys think the arp stud kit would line the head up enough?or best not to risk it?
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
    • I'd want at least $40K for mine, but thats easy to say cos I'm not selling anyway.
    • That's incorrect. We have 4 seasons, consisting of pre winter, winter, post winter and a small glimpse of hope!
    • I spotted a black C34 in Mittagong this morning!
