Hi, I've just been offered an R33 Turbo that's been machined on the front inlet part and then the rear cast part has also been opened up a little too... Can get it for $700 as a complete kit with all new blue silicon hoses. Just wondering if that is a good price, the bloke recons to machine a turbo in that way it would cost upwards of a grand. It will be going on my R34 Neo, would this be a good upgrade for the price?
Also does anyone have any idea what i'd then get for my standard R34 neo turbo?
https://www.sau.com.au/forums/topic/396585-whats-a-hi-flowed-r33-turbo-worth/
Don't do it. Unless you can know what wheels etc have been put into it, it's not worth a single dollar. Also, the R33 rear housing is smaller than the R34 rear, so even though it has been highflowed, you would be better off sending your R34 turbo to Hypergear and getting it flowed for not a lot more than the $700 they want for this other turbo.
I was talking to a guy from GCG Turbo's yesterday at Jamboree about high flowing my r34 turbo and he said after its machined and replaced the compressor etc. ect. it'll cost upward of $2000+.
Don't know how true it is but its something to think about...
I recon ill be going the $900 option... Don't need anything too Fancey just a little better than stock for now and kinda got excited at the price and look of the high flow... It was coming from my bro on law whose a.pretty good salesman haha...
I paid $1800 for GCG to hifghflow a GTST turbo about 3 or 4 years ago - wouldn't do it again - the Hypergear seem better value for less money or at about the same money or a little more you can get some good new turbos (although you may need new lines etc).
I've got a hypergear high flowed r34 turbo and once I get my ecu issues sorted, I will hopefully be putting it in. The dyno graph in the hypergear thread show it on an r34 putting out 260rwkw on 17-18psi bleeding off to like 14ish psi up top.Ill be hoping for about 240kw or so on my r33.
high flowed turbo do make noticeably more power on stock ECU, you can run about 10psi of boost without upsetting the factory tune. How ever it doesn't make the full potential unless you have aftermarket ECU, injectors and the rest of supporting mods. The best is to get the turbo installed, then have fuel mods done at your tuners with car tuned on nistune chip. I've been told stock afm support up to 250rwkws, so Z32 AFM might not be necessary for the high flowed turbo.
No point wihout the Nistune. Depending on the turbo you will also need a Z32 afm and bigger injectors (and you should replace your fuel pump with a new and better one).
Since you will also need (if yours is stock now) a FMIC and at least 75 -80mm turbo back exhaust. If you're on a budget do these first with the Nistune and then get the turbo, afm and injectors and retune.
Ask about the specifics, receipts etc. I bet it has a journal bearing core - nothing wrong with it though. If you can prove it really is a high flow, then offer him around 650.
Its definitely been “hi flowed”, but as for specifics we don't know... He bought an economical right off and it was on the engine in that car. Thats all we know. The seller is my bro in law so i know he's trustworthy and not rorting me.
yeah , its so easy to carried away buying a turbo..you start of looking at a budget hiflow, then realize for an extra few hundred you can get more power..
But in reality its not that easy..cause there is always extras needed to make that power...
looking back at my own mess, a budget hilfow and an ecu with a good tune is where I should of stopped..you can keep stock injectors and afm and still make a comfortable and zippy 220kw without worrying about destroying your driveline every time you sink the boot in..Plus it will still look stock should the popop start poking there noses in your business
2500$ will get you a 220kw quick and easy to maintain car
5000$ will get you a 280kw weapon and alot of headaches
Its just so easy to get carried away upspecing everything....
Direct from the RB25 dyno thread:
R33 Series 2 5spd manual
Stock RB25det series 2 engine
-3" turbo back exhaust
-Hypergear Hiflow 21U housing (R33 turbo hiflow)
-stock afm
-Pod filter
-Stock injectors
-Frount mount intercooler
-wolbro fuel pump
- Ecu tune by Toshi (by me)
Makes 263rwkw on only 15psi
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
