  • Replies 193
Good to see red bus and the canadians on board. I hear the winfield GTR will be entering too :O
So the mini wang is not the mega for this round but will start slightly differently to the usual, the long wang has new chicanes and is a tad longer. The idea is to have more time for battles with a proper knockout at the end of the day.
Looks a bit light on so far with the numbers. I think its time we all did a recruiting drive and get some new entrants along. If you have mates with a car sign them up. Like everyone says, it doesnt have to be anything special.
That and cars dont get impounded ;)
And evos suck
nar the winfield will not be there its getting work done!!!!! ready for track days just the GTS-T will be there at this stage LOL!!! never no dad might get a itch and we will bring her out lol!!!!
looking through the supp regs it doesnt appear to mention anything about ext gates venting to atmo.. yay or nay?
Only reason I ask is that I have a friend in his 34 GTR that would more than likely come if its allowed..
lol.... bring them. they will be fine!
And evos suck
Been trying to recruit outside of SAU already. So far I've had a tiny bit of success.
Edited by llama_au
Seeing as Automatic Evo's were never sold in Australia and you can't import them - I'm curious how you are going to supply me with one to drive :P
Unless you're just pointing out the fact they drive themselves?
we have a number of cars running large high mount turbo setups with straight pipes and screamers ;)
the louder the better i say :laugh:
also ive been askin mates and some are interested but most are going to winton cause they have a prac day same day as deca :unsure:
umm google evo 7 GT-A.. Fun cars to drive... for about 5 minutes
bloody mexicans and their lack of rules! Wish us silly NSW people were allowed to do this at our events :(
Bingo.... Just enter the cube. Should end up with some "well rounded" results.
ive tried getting her to enter the cube a couple times, she just laughs at me :whistling:
    • Hell, I'm sufficiently wary of the ZSS suspension arms, let alone something like a hub.
    • Got it back home and got started pulling the hub off and diagnose the issue. Axle was stuck after removing the 36mm nut so i used a 3 jaw puller to try and push it out and... eH5FXvJ8.mp4   spend the next few hours trying to remove the axle from the remaining hub as it was very much jammed in there when the spindle sheared off. resulting damage as below R53AIy6 - Imgur.mp4   Looks like the was already a stress fracturing in the spindle as can be seen with the darker cracked section My working theory is maybe when the pinion gear exploded last year the shock put through the hub was the initial crack. Then a few events later it finally let go. Just lucky it happened where it did and not 190km/h on the next sweeper or into the hairpin The bearing/hub assembly went in in 2019 and were non-genuine "ZSS" assemblies and no nails were harmed in the process. #BreakHubsNotNails
    • Thanks mate, couldn't find in VIC, ended up ordering one from NSW, getting rwc to get new plates and registration done.
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
