:laugh::laugh::laugh:
cause Im bored at work and this thread made me laugh, I had to express my laugh in words somehow... I chose sarcasm
:laugh::laugh:
Oh yeah.. silly me :blush:
:laugh: lol
Enough trolling from me........
  • Replies 98
Posted Images
I was just about to order myself a Link G4 Plugin today for my GTT! Im still keen on the Link but I'll have a look at these Adaptronics too, they didn't have anything for the GTT last time I checked.
really...no PFC even :blink:
..I know adaptronic have just released one....
Damn another free plug, I should be getting paid for this..
Do you even have all the supporting mods like FMIC, Fuel Pump, ECU, Injectors, Clutch, Diff, Oil cooler, Radiator, Coil packs, AFMs, a FULL fluid service from motor, gearbox to diff ???
Ive got a FMIC, Fuel Pump, Clutch, Coils, only a stock Dump Pipe
I'm fine with people not responding to this anymore unless you want to. I found some examples of what i was looking at and appreciate any helpful replies. I will continue to look into this.
thanks.
thanks.
ECU
INJECTORS
FULL EXHAUST + HIGH FLOW CAT
EBC - BOOST CONTROLLER
The list will go on...
This forum is full of all the information you would need and there are some good examples in this thread...
The guys will have a joke and its simply the good SAU humour... But the info is already here for your taking so do some reading and good luck
Dont kill anyone :thumbsup:
thanks.
So you are basically only half way there in terms of supporting mods expenditure.
Spend the $3500, you are going to waste on a turbokit you cannot make any use of, on the remaining supporting mods you've missed. Then you'll be ready for a turbo upgrade.
I used to spend around that crazy amount on pc gear... back before I got a car... rewmeber it took nearly a year to save up for an Nvidia 7800GTX...
took up the one PCI slot plus was so big it covred an express slot below it and it was so heavy with it's massive heatsink I had to make a bracket to hold up one side.
If you are that paranoid about security I imagine you would have a fairly sofisticated firewall possibly behind a proxy with a dmz?
listen to what these guys are saying about mods, like a pc, you can't get some top of the line i7 with a mobo that has onboard gfx and wonder why u can't play any games with a good res and top antiantalising, the system is only as good as it's worst/cheapest component.
eg your clutch, what brand/model? you may have upgraded it and it may only be able to hold 240rwkw and your looking at 300kw+ turbos.
they were only released a few weeks ago..
At 1499 for the adaptronic the link still probably represents better value for money at 1600.
I think if the adaptronic would drop its price into the 12-1300$ range though It would be a great buy
Have you tried calling GCG Turbos or somewhere like that? They'd give you best advice on what turbo kit you need!!
I'd suggest you get a PFC before you get a kit first but...otherwise your kinda working backwards! And at least 550cc injectors...you don't want your injectors working 100% duty at 4500rpm lol
And thats easy 5g their before labour costs....sucks doesnt it hahaha laughing-smiley-014.giflaughing-smiley-014.gif
It was more that the Adaptronic comes with a usable 4 Bar MAP sensor, rather having to buy a bigger external one for the Link, and it also supports knock control where as you have to buy the KnockBlock for the Link, so with that in mind it's well priced. Still I have decided to get the Link anyway due to the software it uses.
Yes It is still good value, I just think they may be a more popular choice if the price was a little lower.. ;)
The only place I think it loses out over the Link is the the lack of full sequential. But this wasnt a big concern to me..
Trent was going to to do some tests with mine when on the dyno to see how accurate the knock control was too..not sure what happened to that :unsure: I will remind him next time..
but the added map sensor is definately a bonus and I'm using the inbuilt boost control too which was is easy as hooking it up to the stock solenoid, so there really is nothing else to buy, well the only other thing I needed to buy was an IAT sensor for 40$ maybe they will throw that in if you ask nicely..:)
While we are talking turbo upgrades, how do u think this set up would go. I have a s2 R33 with FMIC, Cat back, Pod filter. so im guessing around 180kw at 10psi. So if i was to get a nistune or pfc, a kando TD06 20G internal gate ( i wanna stay internal, i also know about hypergear but i want a kando) and a walbro or tomei fuel pump and run 15psi it should put me up around 230-240kw ? (50kw gain) That a pretty cheap upgrade. Plus other bits and pieces like a custom dump and obviously a tune. I just read the stock injectors will flow enough at 15psi in another thread. im not after 300kw but just something that will come on a bit later and harder than the stocker without breaking the bank and fuel economy.
Stock injectors won't make it past around 230rwkw and even if they do, you'll be loading up the fuel system big time, maxing injector duty etc.
If all you're after is ~250rwkw then, as ARTZ said, get an HG. From what we've seen the Kando internal gate setups aren't fantastic (yet), these turbos only seem to come alive in an external gate setup and then they have potential for a great top end...but that's probably overkill for you, given your modest power goals and desire to stay IG.
No its what you do when you spend 6k on a computer and optimise every component for performance.. none of these posts are at all helping.
$6K?
I built a:
Intel 2011 Socket 6 core "K" processor
Corsair 16gig Ram
Asus z78 Mainboard
2 x SSDs in Raid 0
Watercooling
Nvidia card worth $600
Coolermaster HAF-X Case
Corsair 1150watt Powersupply
Total cost was $2.5k.
If you're spending $6k on a computer, and you're an IT expert, you should leave this site and save us heaps of trouble becuase soon you will be a skyline expert asking us why your car stalls after you have fitted a chirpy, twisty, shiny, flappy ATMO BOV.
Edited by The Mafia
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
