Hi,
PM sent - correct the ID's are actually EV'14's just flow matched by injector dynamics. Not sure about the milling though as I haven't heard of it.
- Brendan
  • Replies 191
Hi,
- Brendan
Can you please also PM me a price for the ID 1000cc injectors to suit an R34 GT-T, with the plugs. I'm looking for something that is pretty much drop in on the standard fuel rail.
Thanks
Justin
Thanks
Justin
Hi,
These would not be a direct fit as they are universal injectors, but with extensions and plug's I can do 6x 1000cc EV14's for just $630 incl. delivery! These are readily used on the R34's so installation is no major issue if using an experienced workshop.
- Brendan
  • 4 weeks later...
Hi mate I'm looking for some E85 1000cc injectors to run in a BNR32 with 11mm HKS rail, SARD regulator & warlbro 450lph pump, cheers.
Hi,
I would go with the BOSCH EV14's 1000cc top feed injectors. They are E85 compatible and come with extensions to suit 11mm o-ring.
Can do 6x with extensions and USCAR plug for $630 incl. delivery
- Brendan
  • 1 month later...
Hi
Chasing some prices on 700-800cc injectors for RB25 (Side Feed)
May be interested in going top feed if there is a good deal on a package however :)
Thanks
Hi,
The side feeds would be $150/injector so if you can go top feed that would save a lot of $$$!
Top feed BOSCH EV14's 1000cc are $640 incl. delivery for 6x which include the extensions and plugs.
- Brendan
Hi,
- Brendan
Hi Brendan
Thanks for that, so with the injectors, extensions and plugs they are pretty much plug and play (minus the rail of course) or do they need the resistor pack?
Thanks
Callan
Hi,
They are practically plug-and-play but you would need to contact a workshop to get specifics on what else may be required.
These have been widely used on the R33's so certainly no major task as all.
Also note these are the same injectors as used by injector dynamics!
- Brendan
  • 1 month later...
hi there I am after a set of injectors for 450kw gtr im thinking id2000? How much for 6 with the required adaptors to fit stock fuel rail and connectors I assume they are not plug and play and need some work from the tuner?
Scott
Scott
PM Sent :yes:
