  • Replies 58
Avoid driving it dude, because lean afrs on cruise can and will burn your exhaust valves.
why would it be lean on cruise? i think your right with any boost it is leaning out, that must be why the light started flashing on mine, or maybe the tune.:whistling:
Here is how the intake was setup when it was stalling.
This is how I had it afterwards to fix the stalling. I'm more convinced it was the ripples in the flex pipe than the extra length and bend, obviously had the air filter on for the test, this was taken before I put it on for the sake of the pic :).
Its the angle the BOV enters, not the bend that causes the stalling imo. It looked like a nice intake until you ditched the airbox. :thumbsup:
I have to agree with scotty here
You can imagine the BOV just venting and bouncing around in all directions disrupting the flow.
When Scotty designed mine it dumps into the intake on an angle towards the turbo
Yet another thread full of mafia's condescending crap, i hope it makes you feel tough :thumbsup:.
Not really hey, I've seen the AFRs after many of these upgrades and I know for a fact that they run lean and its not advisable to drive them far or at all.
So, dribble your shit elsewhere.
I wondered the same thing, but I've seen it on a few cars.
I'm thinking that at 2,500rpm and above the turbo is spooling a tiny bit, making the air path easier into the motor. Being a bigger turbo, its able to help more air into the engine. Think about it, at those revs, the turbine is spinning at a notable speed. The compressor would be "helping" the air get into the engine easier on vacuum, allowing it to breathe easier.
What had been tuned to 14.5 - 14.7 afrs on cruise, I'd seen go above 15. Also caused the engine to run a little hotter at cruise due to being a little leaner.
Not all but a number of cars.
Oh no not a 5% rise in AFR's, how on earth are the exhaust valves going to survive that. Load is determined by the AFM, unless theres a leak or something else isnt working as it should then its fine to drive normally. Sure the AFR's arent always going to be EXACTLY the same as they were before but your not going to kill your motor by driving it around under light load. It takes AFR's upwards of 17-18:1 to do any damage to valves and pistons under light-medium load and you'd know all about it if it was that lean.
i agree to this , the engine seems more powerful even without boosting compared to my old highflow i had, and that is significant , and its odd but i think true... and with cams i find it even more noticable..
Edited by SliverS2
No worries. So you just take your nose out of your ass shove your nose up the exhaust and have a sniff, and go "Yep, shes safe enough, thats about 16:1"
My whole point - Unless you have a wideband you have NFI. So is it worth the risk.
I've also seen cars cruise fine at 17:1 without a miss. Wonder how those exhaust valves are doing.
Who knows. But nah, she'll be right hey. Just spent $6k on a turbo upgrade, its just money. Who gives a f**k about the engine.
Its ok though, my cars will always be safe. And the people that listen to my advice.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
