Our GTST has a sensor in the bottom of the radiator that has a plug on it that looks like this
I can only find ref. to this sensor with respect to the GTR models, should it be plugged into anything on a GTST?
Thanks,
Sam
Edited by savage1987
https://www.sau.com.au/forums/topic/397133-radiator-sensor/
That's the thing.. I have had a quick look around and can't see a plug for it anywhere. The temp gauge in the dashboard works fine, but I think that's fed by the manifold coolant temp sensor...(?) Unless this one feeds the ECU .. that'd explain why the thing seems to enjoy 14L/100km :(
https://www.sau.com.au/forums/topic/397133-radiator-sensor/#findComment-6306026
The ECU temp sensor is on the alloy coolant pipe out of the head in front of the inlet manifold. Single spade connector and single wire stickign up. See this thread for further VERY recent and searchable thoughts on the radiator sensor. http://www.skylinesaustralia.com/forums/topic/396808-radiator-thermo-sensor-question/
https://www.sau.com.au/forums/topic/397133-radiator-sensor/#findComment-6306056
The ECU temp sensor is on the alloy coolant pipe out of the head in front of the inlet manifold. Single spade connector and single wire stickign up. See this thread for further VERY recent and searchable thoughts on the radiator sensor. http://www.skylinesa...ensor-question/
Yeah thanks champ, I see what you did there with the hint that I should have used the search function that never ever works properly on any forum...
That thread still doesn't tell me what that sensor actually does, all I have to go on at the moment is guesswork and wishy thinking.
Sam
https://www.sau.com.au/forums/topic/397133-radiator-sensor/#findComment-6306131
Didn't you read Moodles2's post? Tells you right there that the sensor turns on the A/C fan (in front of the A/C radiator) in overtemp situations.
GTSBoy - the single spade temp sensor is for the gauge, the ECU reads off the 2-pin sensor.
https://www.sau.com.au/forums/topic/397133-radiator-sensor/#findComment-6306341
I did read it. "... generally means ... " is not a 100% answer :P
but it seems to line up.
Anyway I found the plug for it this morning, jammed between radiator and A/C condenser and full of black scunge.. gave it a quick clean up with some elec contact cleaner and plugged it up. Maybe that fan will work now :)
https://www.sau.com.au/forums/topic/397133-radiator-sensor/#findComment-6306406
True, true. Brain fade right there. I was only playing with that (single pin) sensor a couple of weeks ago when doing the engine transplant to make sure that the R32 gauge would work correctly (just in case there was any difference between 20 and Neo sensor resistances - still haven't gotten around to testing if they're the same or not either).
https://www.sau.com.au/forums/topic/397133-radiator-sensor/#findComment-6306517
And.... this afternoon I found out why my sensor's wire has been hanging for years. I found the other connector all hooked up to a relay tucked down between the battery and headlight. It seems that between me, my mechanic and possibly the guy who does a lot of the wiring in his shop we did something about ten years ago to it, and we can't remember why. Might have been at the time we did the auto-manual conversion. Vague memory is vague.
https://www.sau.com.au/forums/topic/397133-radiator-sensor/#findComment-6307012
  • 5 years later...
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
