  • Replies 7.5k
Posted Images
Hostile when i waved i nearly hit the car in front of me. I didn't notice it stop, thank god for good brakes. I think i need to use that inside lane a s you always come from nowhere and dissapear into the distance while i never seem to move >_<
Yep for sure... the inside lane is always movin well cept for buses!! I always stay inside and change after the split for Ayliffes rd. Only a few km from there to work for me!
ok who was the fool who decided to fishtail it out of bp servo at pooraka. i was driving past there this morning to work, he must have seen me and wanted to prove a point. roads were wet at the time, he exited the servo driving on the limiter, i could hear it bouncing off the rev lim. seriously, its ppl like YOU who get us targeted. was a marron r33, wasnt you was it redgtst?? raises eyebrow*
WTF why does every one think that as soon as a Maroon car does a chirpy or something that it is automatically me!!!! Thr fricking cops do it tooo, one guy said he recognised my car and i had never even frickin seen the dick b4.
As for being at Pooraka WTF i would not be seen dead out there! my ride would get stolen in Boganville.
Hmmmmm -SKYLINE-?????
hmmm :) yep that was me!!! i nailed it in second until i noticed that there was water on the road from the sprinkler system......... damn council..... watering grass at 10pm at night!!!
Spotted Marron R33, with unpainted front bar, turning right into Grand Junction Rd from Pt Wakefield Rd south-bound.
Spotted (drove behind him) Black R32 with BN/Vertex kit heading north up Main North @ cnr of Diagonal.
was @ bosotworx today having timing belt done and a dyno tune after that tony had to put my front tailshaft back in and he jacked it right up on the troley jack and he said that how u want it launhing @ the drags fron wheel in the air :whistling: i thought it looked a bit kool to i got my camera and took a photo ... but i accidently had the camera set wron and it came out better than i expected :laugh:
oh enough to bring the front wheels off the ground :whistling:
on a 3rd run he got 175rwkw and stopped short cause it was leaning out
i also got a leak on the plenum so need a new gsaket and need to find a air leak shaun said u only loose about 5kw through the transfer case
oh first run was 140 rwkw (thats how sick it was)
and he said it looks like the guy that got it turbo'ed didnt just wack a turbo on the DE motor that he put a DET engine in so i can prolly run 14psi when i get the rest sorted
Edited by Madaz
Ahhhh sweet, so a new fuel pump for you then???
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
    • Assuming your brake pads are not worn right down, I'd add a little brake fluid. Is there any sign of a brake fluid leak?
    • Hello all,  I need of some help. On my drive home my handbrake light lit up and started flashing. When I got home I checked my handbrake sensor under the centre console and nothing seemed out of the ordinary. I have scanned my car via the consult port, no codes shown. Checked my brake fluid as well which is half full. Tried unplugging the brake master but it didn't change anything. Thoughts on what it could be? The master float doesn't seem to be stuck. My car is an 1998 ER34 sedan GT. No hicas but has ABS Photos below 👇🏾
