great idea!
are there currently any stickers available or if not i wonder if anyone on here is able to make some to order?
ive been offered sum by a girl in brisbane but i dont know how many and if we have to pay she asked me how many i wanted :)
i more or less said how many have you got... its this 1
http://www.skylinesaustralia.com/forums/in...st&id=54630
  • Replies 7.5k
Posted Images
personally, i dont like that one at all.
I much prefer Howie's design in the "GTR" shape - would look great over the GT badge on the front guards - not too obtrusive, but easily identifiable to other SAU members.
That would be me, 34 4 door looks cool in that colour.
Awesome car mate - so very clean! I am not big on white cars, but for some reason R34s (especially Rs) look great in white! Do you live around here - I am like 200m from the shopping centre. Would love to get some photos of them together!
Pity mine was absolutely filthy when you saw it :P .... but thanks for the compliment anyhow
Cheers. I live just across north east rd. It looks clean from a distance but you can see the dust and collection of (f%#@ing) cat paw prints all over it when you get close.
Yours sounds better than mine, silly stock GTR exhaust is almost silent.
Photos would be cool.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
