  • Replies 7.5k
Posted Images
wat the hells goin on here, as soon as someone gets their car back, someone else cant drive theirs..... remember ppl when u replace parts, make the stronger. my motto anyway. otherwise i would have payed 450 for another stock turbo and fitted that instead... f that lol.
GUESS WATTT, MY CAR IS BACKKKK
Yay! Vange is out and my car is in. I saw it loaded onto the tow truck today. Two new HKS turbos + HKS dumps + major service and I'm back on the road (in my grey GTR). Now I just have to get a starter motor for my Peugeot to get that going again.
So apoligies in advance if i overtake/cut u off/speed/etc etc you over the next week, as i am going to make up for lost time...
hahaha
Yeh nice one Vange....... I saw them putting it back together on saturday, and thought you'd be happy! :)
spotted vange... on the road! =)
driving past my work today at about 12 (i was behind you in the bosses ford) as you turned onto hindley street
nice looking car, i bet it looks even better under the hood :)
Edited by Fishpaste~
spotted mr.nisswreck in his r33 im pretty sure near holden hill police station on my way to indoor. did anyone see like 20 cop cars flying around holden hill police station with lights flashing, i think there was a robbery close by.
yep that was me, were you in ur 33? i didnt see ya
haha nah dude, i got a lift to indoor cause my clutch is f**ked, remember? all good tho, ordering one today and getting it fitted end of next week for the weekend.
Saw you too Mr. iNFMS, that is if you were the dude in the white R32 last night filling up...
Spotted Dodgy today on NE Road, nice catching up with you buddy and nice little thing you had in the passenger seat too :( An improvement on Salvo :thumbsup:
Also saw a Stagea on McIntyre Rd, gave him the nod and thumbs up, you on here buddy?
Spotted in my street monday night a black S2 R33 with chrome starcorp rims on it
Today on my way around the salisbury highway area spotted black R33 GTR with plates GTR2NV or something along those lines..Looked and sounded tough as!
Must have not been you then mate, the fella looked right at me and smiled, it was also silver colored, yours (if the pic in your avatar is correct) is white
oops. well I was on mcintyre rd a couple times that day also, for what its worth :P
wonder if the owner of the silver stagea is on here then??
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
