Spotted a white R32 with a bit (a lot) of Drift damage on Morphett Road about 20 mins ago :) it definitely looked the part though.
Dan was in the Passenger seat, I know who you are because I know a few (most) of the TeamSR boys as I'm an RPMLounge admin.
yeh thats dougs car its a drift pig an a half lol yeh ur car is a very nice 33
  • Replies 7.5k
Posted Images
oops. well I was on mcintyre rd a couple times that day also, for what its worth :)
wonder if the owner of the silver stagea is on here then??
How many Stags can be in this neighbourhood?
Mel & I live just off McIntyre.... white 97 RS4
I have seen the silver one @ Mod hospital often
Spotted yesty around findon area a black 34 with what looked like enkei wheels on it, and today on main north road heading towards gawler was a white R33 with blue racing stripes down the middle of it...
theres a white r33 with plates 'RH1' that sits at a car park in front of mitsubishi motors.. looks stock but nice cooler on front!!! nice car
i remember that plate, it was for sale a while back, i was half interested in it at the time. Was it still for sale dude??
yeah i've seen that one heaps too.
Also a black s2 lives nearby too, seen it twice before. :D
cruzed round city last nite. heaps of nice cars out. only one i recognised from here was the orange 32 "NOT URS".
i was the one that pulled up next to ya askin bout the ignition cruz in a white 33 wit black 17s.
Hey! Didnt realise you were from on here lol, should have said something. Dunno if u saw me earlier when i first went past, gave u a toot n wave then had u catch up to me. Car sounds good!
Saw a heap of cars - skylines and other imports comin back from ignition cruise, i was lovin it lol, had to try concentrate where i was going while watchin them all go past.
Saw madaz and his mate in his 34 down the bay and then again at csa meet spot. Nice catchin up with ya again.
Saw 'Robski' white 33 in carpark up at lala today, bout the only car i recognised
Has anyone seen a black R33, GTS-t it looks like with the plates BLKSKY driving around the city, think he works in there somewhere. Saw it again the other day going down pirie street.
Also a blue R32 GT-R with the plates GTRRR 1. Anyone on here..?
Hi there... I was the guy in the BLKSKY that you saw.... Sorry for the *super* late reply thou...Just got back from a long*** holiday. :laughing-smiley-014:
I was probably on my way picking up my girl off work at Pirie St. :bunny:
I was probably on my way picking up my girl off work at Pirie St. :nyaanyaa:
Ahh your on here :domokun: Was wondering why I hadnt seen ya for awhile, usually see you everytime im in the city, havnt been in the city for awhile tho, during the week anyways!
Spotted yesterday around 4-4.30 a purple 33 GTR with the platez [CC396H] down at moana. If your on here i was in that blue 32 GTR that followed you down the espy, til you turned off, probly thought I was following you :laughing-smiley-014:
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
    • Assuming your brake pads are not worn right down, I'd add a little brake fluid. Is there any sign of a brake fluid leak?
    • Hello all,  I need of some help. On my drive home my handbrake light lit up and started flashing. When I got home I checked my handbrake sensor under the centre console and nothing seemed out of the ordinary. I have scanned my car via the consult port, no codes shown. Checked my brake fluid as well which is half full. Tried unplugging the brake master but it didn't change anything. Thoughts on what it could be? The master float doesn't seem to be stuck. My car is an 1998 ER34 sedan GT. No hicas but has ABS Photos below 👇🏾
