i was more there around 8:30ish, going past sipnsave.
yes dean. it was most likely me.
Yeah it prob was more like 8:30, was sitting in Cafe Bravo and you pulled out of one of the side streets onto the parade....nice ride!
  • Replies 7.5k
Posted Images
if u mean nice by, it was clean cause i cleaned it that day, and, it sounds good, or, it goes fast, then thanks.
i have stock 16's on it, no body kit, a front mount and an CAI in the left side of my front bar...
Spotted a nice white 34 heading south on kingwilliam in the city this morning at bout 9 am. May have been the one from the autofest photos next to flick's car?
Then on belair rd where i was working a black 33, silver 32 and a white 32 all heading towards the city at various times
If it was round lunch time when you saw the black 33 that would have most likely been me >_<
Saw olds32 at the goodwood rd and daws road intersection and saw SKY095 a very nice 4 door 33 on rundle street on the way to work
I tried waving if you saw me, we were pruning a hedge on the side of road!
Also spotted VANGE MOBILE today as he was enjoying the beautiful scene at the torrens river with someone special.... :/ That probably explains why the "VANGE MOBILE SPOTTED THREAD" has been significantly reduced lately... :/ lol Just kidding mate.. It's good to see ya around.
hahahahaha........dont worry i wont get 2 that stage!
still no spots an i cruised hindly an rundel last nite, might need to ask vange how he dose it. also had jap plates on an didnt get a look even from the boys in blue
ppl r just out 2 c me...thats y lol
2 skyline owners in the same area ( prospect/blair athol boundary )
one in my street and one the next street over - if ya on this site ill say hi
black r33 coupe with bbs type rims, the owner lives near a round-a-bout
the other
blue or black r33 sedan , nice exhaust
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
    • Assuming your brake pads are not worn right down, I'd add a little brake fluid. Is there any sign of a brake fluid leak?
    • Hello all,  I need of some help. On my drive home my handbrake light lit up and started flashing. When I got home I checked my handbrake sensor under the centre console and nothing seemed out of the ordinary. I have scanned my car via the consult port, no codes shown. Checked my brake fluid as well which is half full. Tried unplugging the brake master but it didn't change anything. Thoughts on what it could be? The master float doesn't seem to be stuck. My car is an 1998 ER34 sedan GT. No hicas but has ABS Photos below 👇🏾
