  • Replies 7.5k
Posted Images
are they nsw plates on the hummer?
there was a black h2 i saw around a while ago looked heaps better then that, running 26" chromies with s.a plates
spotted 2day on curtis rd turning on2 main north heading to galwer white r33 white centred impuls n blue racing stripes :s looked clean apart from the stripes
Edited by shy_s6
saw madaz on north east road infront of kfc doing a u turn
think i might have heard abit of limter :P
lol guilty i was catching up to the silver R33 heading towards St Agnes got half way between hungry jacks and the TA bus depot and realised i had to get money @ TTP DOH!!
on my way down to grans tonight in the volvo mobile spotted a black 33 heading to city on bridge road then 30 secs later a maroon 33 heading same way
oh and down on torrens road a silver 4door down from the Challa Gardens
Spotted green/aqua R33 S2, number plates [bB07IY] on panalatinga road turning onto south road last night at 9.30. looked to have white impuls, no body kit. Clean looking car if your on here. See it heaps in the happy wash on south road just up from sturt road near the future car sales place.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
