  • Replies 7.5k
Posted Images
Steve,
Nankang NS2's simply... suck. :D
I had a mates 245/40/18 nankangs on my R32; straight line grip was worse than my el cheapo 225/50/16's and cornering was very understeery. They were basically new tyres. OH and they were super slippery in the wet both straight line and cornering.
That is compared to my 225/50/16 Federal 535's which are cheap tyres in their own right.
Purely for their poor wet weather performance I wouldn't touch them.
BUT a set of new Nankangs will still grip better than a stuffed set of better tyres so either way they will feel better than what tyres your running now. :)
I'd look at something else.
Ah cheers for feedback joel just sang him and told him iv.e changed my mind again :D he be sick of me by the end of the day lol he said he will do a ring around and see what other skylines are running and get me a decent cheap but good wearing tire the ultimate paradox
I had Federals on the second hand set of 33 stocker rims when i first purchased them, and i must say, they lasted me the longest out of all the 225/50/16 tyres ive ever put on the 33! ... Khumo, Nankang, BobJane, Michelin all lasted nowhere near as long.
Performance/Grip is another thing tho eh!
Edited by MSPEC33
saw cara's 34 the last couple of days out the front of clipsol
yeah i was working in the kitchen on tues and wed.
spotted a white r34 with black rims/nismo front turning from henley beach rd onto south rd, and also on south rd spotted a white with pearl r34 4 door...............looked very nice ;)
Longest lasting tyres... The no longer Simex. They used to be fairly grippy when new but quickly went slippery.
I've had sava's; they chew out really quick and don't offer the same levels of grip in dry and wet that the cheapo federal 535's do.
I don't believe you can get the 535's in the 17's so you may be stuck with 595's which by all means are an awesome tyre but no doubt cost a little more.
As I said.. I was unbelievably disappointed with the NS2 245's; I couldn't believe a cheap 225 would hook up better than Nankangs flagship tyre. :S
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
