  • Replies 7.5k
Posted Images
spotted last night around 5:00pm on sudoltz- lower north intersection a white 33 gtst with gold rims and a black haired hottie driving it, nice car and awsome to see more girls in tough cars
mike
Spotted Dan in his 32 near BP Belair last night about 9:30-10, coming up the hill!
thought it was u only saw little bit im like arrrr oh well on way hm from date so was in hurry for hm. was a beautiful nite for crusing so far loving this weather
anybody else goin on nite crusez during the week so far been on one everynite
Spotted a wine red 33 gtr heading past metro holdens yesterday, and some dude in a purple 32 on military road noticed me admiring as i walked past him so he give it a boot haha also yesterday.
And i was starting to think there were no skylines over the west side
Please someone else told me they spotted a HOT HOT r34 in bayside blue with kit rims etc? Saw it yesterday arvo on henley beach road, would have to be one the hottest 34's in adelaide.. ive never seen it before. Not sure what kit it was but damn it looked awesome.. kinda veil-sideish but not so out there.
Regret not going back now to take a photo cos damn!
odd sighting
last night at around 8.15pm spotted a white or yellow r33 coupe parked on Pt wakefield rd just after the the globe derby park intersection
( if you heading north )
it was parked where the pine trees are on the gravel
no one inside - no hazards lights on , no other cars around
weird
hmmm.. maybe the unfortunate victim but the all too common bear attack while taking a wizz in the woods :w00t:
Any visible For Sale sign? Could report it, if you managed to get it's plates to see if it's been stolen.
Seems to be quite a few female varieties driving the Skylines these days, Thats def not a bad thing, but people will be calling them girls cars soon....... :w00t:
Tell me about it!! I do about 800km a week and see countless imports. 90% of silvia drivers are girls, 100 % of 180sx drivers are guys for some reason though and skylines are about 50/50! Havnt seen a chick in a GTR yet though except my g/f :(
Ryan
Tell me about it!! I do about 800km a week and see countless imports. 90% of silvia drivers are girls, 100 % of 180sx drivers are guys for some reason though and skylines are about 50/50! Havnt seen a chick in a GTR yet though except my g/f :w00t:
Ryan
my friend just got a purple gtr.. yeah she is a chick too!
spotted a white 32 going up hancock road around 2pm.
Ryan
what are you talking about kat is a chick driving a 180sx silvia
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
