  • Replies 7.5k
Posted Images
yeah fredman saw u too! Shouldve said hello :laugh:
saw waaaayyy to many to remember today! Down jetty road - black 34,glittery blue 34 and a white 33 all cruising together. the blue one was the same one i saw few weeks back, seriously one of the HOTTEST 34's getting around by far. glittery-blue, black bonnet, hot looking kit. Was almost hanging out the car to look at it some more. *droooool*
glittery blue 34 - the blue one was the same one i saw few weeks back, seriously one of the HOTTEST 34's getting around by far. glittery-blue, black bonnet, hot looking kit. Was almost hanging out the car to look at it some more. *droooool*
i saw this 34 on a side road off of gouger a few weeks ago, looked damn nice! ne1 on here own it? ne1 on here know the owner? reminded me a lil bit of autostyles 800 hp 34 from sydney i think, very nice 34!
lol... Quite obvious they would do such a thing as weather warms up.
Where abouts at the bay?
as u go down jetty road. cross the tram crossing and the bit where pedestrians cross, it was on the left where the bikes usually park.. sorry hope that makes sense. there was a single cop car with some witches hats around it and they had a vp pulled over.
i was in my maxima so they didnt look twice at me. :laugh:
seen the neat 31 at work today had sau sticker on front window, plates were thrty-1 me thinks
thats my mate alan in his 31, we go cruisin a fair bit
haha, i was sittin next to ur car in the carpark thinkin it was the dude i was meetin up with lol then i got a txt from him sayin he is on the other side lol
but NOT URS is a bloody nice car, and i want mine that colour hehe
went all over the place yesterday and saw soooo many nice cars out.
at victor saw a nice 33 gtr with an upgraded twin turbo cooler and a yellow 33 fairly stock looking and a 32 that ive seen somewhere before not sure where though. on the way back saw cooper AGAIN (stop stalking me :laugh: )
then went to seaford and got asked what sort of commodore my car was from an old lady :s
on the way to moana saw a purple ceffy and two 32's both drivers in the 32's waved both were a dark charcoal colour looked nice :w00t:
Yea saw Fredman and *Flick* at ingle farm yesterday. Flick's car's so much nicer in real life but I was in too much of a hurry to really admire it :laughing-smiley-014:
Spotted a Midnight purple 33 the other day near Autotech
Edited by thanglongz
seen one hot as f**k 34 gtr v-spec bout 11am this mornin near vilis. vic rego, nice WIDE volk rims (with the blue light weight wheel nuts), nice subtle carbon diffuser under the rear and a very quiet (yet not stock) exhaust note
i nearly went up the median strip in my dad's car i was paying so much attention to it LOL
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
