Spotted the SLED at boostworx today didn't clic that you were on here till I had left otherwise would've said hello
That bike is insane I had a laugh at the back tyre its like a 265 or something, crazy stuff, I love it.
300 actually .......... would've been good to meet you........will no doubt catch up again.
  • Replies 7.5k
Posted Images
that would be bezender
anyone spot me coming back from the free way tonight,?? i spotted a white 32 and a silver 32 my dump pipe doesn't sit flush on my cat so its pretty loud but new turbo is on, go fit the rest of my exhaust tomorrow
had a blast in the hysen tunnels
and big :) to Simon for taking the time to fit my turbo
what turbo did you get steve?
im back on the road after a few days and a pretty late night last night YAY!
spotted CleanGTS-t on Main North Road (was behind you at the curtis rd/main north rd intersection)
i had a feeling it was you so i made my mum take the left turn of (so i could see the rims and yeah) ;)
she beeped and waved at ya hehe
Follwed a white series 2 R33 down south road from Grand junction road last night on way home from work and a bird driving a 4 door R33 yesty down main north road over grand junction road towards town!
silver 34 four door, pretty stock looking, chick driving it, this morning heading into city on umm paynhem road or how ever its spelt lol
Silver 33 opposite my work as i was leaving at 7, had gold nismo rims. Not bad
white 33 s2 down the bay bout 8:30, think i might hav got a wave (or he threw something out his window, one or the other), and comin out onto brighton road on full noise a Bayside Blue R34 GTR
*insert hooooooooooooge chubby here*
Anyone spot that RX-7 at marion/south road intersection this morning bout 7.10? Was sitting on south road in the turning lane to go onto marion road. Had the rear wheel missing and hazzard lights on, looked like the rear wheel had just come off and it ended up there, couldnt see any indents from the axel or rotor in the ground tho, hope everyone was ok, didnt see anyone near the car..
Also a very nice blue colour R32 gts turning onto the expressway on the way home today at 5, looked very nice. Possibly had black rims but not sure..
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
