Hi everyone,
Am looking at installing a double din DVD unit in my R34 GTR.
Mine came from factory with the TV unit - etc, so has the extra interior panels in the centre column (As per picture, sorry dony have a close up of the centre bit).
For those who have already done the conversion - do you have to source and replace the actual air con unit (as my current one seems a bit smaller than it does on my GTT and other GTR's).
Or is there a different larger facia which you can buy that snaps on to the existing unit?
Cheers in advance.
Edited by iwanta34gtr
The A/C Controls remain and should occupy the DIN slot just below the air vents.
The double-DIN head unit sits below that.
My former VS2 and Matt's current Nur have had the Alpine INA-W900E double-DIN head unit installed.
It's a superb unit with large screen GPS etc
One SAUer in WA was trying to sell his new unit below wholesale > F/S thread
The thin side strips have a brushed titanium look nearly identical to the standard R34 GT-R facia.
If you're not installing it yourself, Daniel of Carbon Car Systems Blacktown has been used by our family several times now Ph 1800.227.252
He does a lot for SAUers
Hi mate, thanks for the response as always.
Im familiar with the placement of the unit, however as I have the extra TV controls - etc in the centre of the dash, i could swear (unless my eyes are playing tricks with me) that the air con units facia appears a bit smaller than it usually would on the other examples without the TV controls?
if you are happy to lose the TV side of it then that unit can come out. the panels are different as well. the AC controls change. you need the non navi units. I can get them at a cost if required.
you only get channel 7 and no picture anyway
Hi mate, thanks for the reply.
I've taken another picture of my centre column to compare it to one without the extra nav unit above it.
The facia on the air con unit is slightly smaller than one without the nav unit, main question is whether the whole air con unit has to be changed for a new one, or whether there is another genuine nissan plastic facia which snaps on to the front of the air con unit to make it the same as the bigger one (as all the controls - etc look the same).
Cheers.
Mine -
Without the nav unit -
nope they are different. you will need the 2DIN panel and the AC controls. from there its a plug and go affair.
if you need them new - shoot me a message.
  • 3 months later...
Chris, if the Nav unit isn't present is it possible to just insert a double din screen where the former radio and sunglasses compartment were or is the conversion kit required?
Hi mate,
If you already have the air con unit in the correct place, chances are the brackets you have in there can be reused.
Im assuming you have a single din unit with a pocket or similar underneath it. If you remove both, you can see if a double din unit fits in to the screw holes in your current brackets.
Hope this helps.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
