I have run out of success on North American forums and I have searched through here and haven't quite found the answers I'm looking for. So here is my problem.
I have a series 2 rb25 with greddy manifold, q45 throttle body, and I'm running 10 psi. I hooked it up to a consult program and when it is running ok the idle is at 1400 rpms, maf voltage is about 1.5, tps is .45, injection time is 2.5 ms, and my vacuum is at 20Hg. The afr reading fluctuates from 14.5 to 15.5. After i rev the engine a few times the afrs read 10. The idle fluctuates between 500-800, the maf reads 2.5 volts, tps remains the same, and the injection time jumps up to 7.5 ms. The vacuum also drops to 10Hg. The timing increases to about 35 BTDC when I rev the engine and when it drops back to idle the reading is between 5-10 BTDC. I've unplugged individual sensors and the only one that did anything was the maf. When it was unplugged the car would stall.
Some more notes.
I used 1M ohm 1/4 watt resistors to trick the knock sensors. Still nothing it keeps on dumping a ton of fuel and you can hear the maf actually sucking in more air. I've tried multiple mafs, tps's, and have checked the wiring numerous times. I did notice that when the car reached 115 degrees F or 46 degrees C it started acting up. The coolant sensor readings on the consult do agree with my aftermarket temperature sensor so I'm ruling out the coolant temp sensor unless someone else can suggest that it is bad.
Thanks for any help.
https://www.sau.com.au/forums/topic/397420-rb25-problems/
  • Replies 43
It runs the same when the bov is hooked up or not. I've seen plenty of setups that run a q45 throttle body and aftermarket manifold without any problems. It isn't like it is barely missing or anything it is not driveable. Base timing is set to 20 BTDC.
Edited by 95_240
https://www.sau.com.au/forums/topic/397420-rb25-problems/#findComment-6309322
Should base timing not be 15 deg? Why did you put a Q45 throttle body on it? Which TPS did you use? Pretty sure your problem is tune related - you need to find a PFC or the right Nistuned Z32 ecu or as you are in the US maybe get a Link and then you can run your Synapse BOV and ditch the afm.
http://www.linkecu.com/dealers/north-america-dealers/dealersusa
https://www.sau.com.au/forums/topic/397420-rb25-problems/#findComment-6309406
I have tried the timing at both 15 and 20 with the same results. I put on the greddy style manifold and the q45 throttle body is a bolt on and that is why I used it. I'm using the q45 tps. I don't see how the manifold and throttle body can affect the ecu that much. The only problem I could see it causing is a little bit of lag since it is larger. The AFM is still reading all the air so I don't see why it would need a tune yet. I actually talked to a distributor over here about getting Nistune but he advised that I address the problem and fix it. He told me not to tune the problem out.
Edited by 95_240
https://www.sau.com.au/forums/topic/397420-rb25-problems/#findComment-6309413
OK but here is a rare opportunity:
http://www.trademe.c...n-465141160.htm
Dumping fuel sounds like the rich and retard function of the ecu - does the timing change suddenly at any point? I think you should get a tunable ecu regardless but maybe if you can find one swap out your stock ecu for another just to eliminate it as a problem.
ecu to Nistune: http://www.trademe.co.nz/motors/car-parts-accessories/nissan/ecus/auction-463835153.htm
stock ecu http://www.trademe.co.nz/motors/car-parts-accessories/nissan/ecus/auction-464840539.htm
https://www.sau.com.au/forums/topic/397420-rb25-problems/#findComment-6309419
Should base timing not be 15 deg? Why did you put a Q45 throttle body on it? Which TPS did you use? Pretty sure your problem is tune related - you need to find a PFC or the right Nistuned Z32 ecu or as you are in the US maybe get a Link and then you can run your Synapse BOV and ditch the afm.http://www.linkecu.com/dealers/north-america-dealers/dealersusa
Base timing should be 15 degrees but it never hurts to check.
I'm not sure that the Q45 TPS will be able to talk to the ECU properly? Have you checked the TPS voltages in consult to see if they are scaling properly?
https://www.sau.com.au/forums/topic/397420-rb25-problems/#findComment-6309420
I thought it was going into rich and retard as well. I thought I could prevent this by tricking the knock sensors but that didn't work. My initial plan was to get Nistune and have both the knock and normal maps the same. However, the distributor for Nistune told me to try to fix it first. I actually went out and bought a z32 ecu today.
Edited by 95_240
https://www.sau.com.au/forums/topic/397420-rb25-problems/#findComment-6309441
R&R is not as simple as just changing maps. The high load end of even the normal map is spastically rich and retarded, and the knock map just takes that to extremes. And R&R is not just triggered by knock. You actually get it from high TP. High TP essentially just equates to a higher AFM signal than the arbitrary limit that Nissan put into the ECU.
Nistune actually makes it trivial to fix that, as you can adjust the max TP value in about 3 seconds, and then you remap the high load ends of the fuel and ignition tables to get rid of the excess caution (and of course retune everywhere else while you're at it).
https://www.sau.com.au/forums/topic/397420-rb25-problems/#findComment-6309462
I think that explains a lot. I guess it might be freaking out because it is getting such high voltages through the AFM at 800 rpm. About 2.5 volts. It is fine at first but as soon as it is given partial throttle for a split second everything goes wacko. I think this might be related to a problem the tps is having. I didn't state this before because it is acting normal for now. The tps has always had a good ground and 5 volts but the signal sometimes would drop to .15 volts closed and .5 volts fully open. I tried 4 different tps and even put a new one on. I don't know what would cause the signal to sometimes be fine and other times not.
I do have to say this forum is awesome. It took one week for someone on another popular forum to respond and it was not helpful.
https://www.sau.com.au/forums/topic/397420-rb25-problems/#findComment-6309486
It is made by a company called Wiring Specialties. It is one of their premade harnesses that uses all new wiring and made to fit my car specifically. When the car is idling fine the AFM is seeing close to 1.5 even though it is idling at 1400 rpms. The only thing that has been noticeably weird is the tps. I even hooked up the 5 volt directly to the ecu bypassing the harness and grounded it directly to the chassis.
https://www.sau.com.au/forums/topic/397420-rb25-problems/#findComment-6309495
your probably better off just unplugging the knock sensors all together then running resistors in there. It doesnt run off voltage feedback from memory, it runs off frequency (It's early, I could be wrong but its not as simple as voltage)
It looks tune related. Timing and fuel changing as they are suggests that after some driver inputs the ECU is not happy with how the car is running and is adjusting the tune to fix the problem. The R33 ECU's are sensitive and all seem to be a bit different. For example when I had a stock ECU and some mild mods, car would not run on 10psi, would just cut out when it got to certain RPM, and when it was dynoed on 8psi only managed 141rwkw. Where as I know other R33's with the same mods got alot more power then that. Others wouldnt just cut the engine like mine did, but would hit R&R
Take out the resistors in your knock sensor circuit, i dont think thats working, maybe try just unplugging them. I think you will find, as suggested already, find a programmable ECU
https://www.sau.com.au/forums/topic/397420-rb25-problems/#findComment-6309820
I've already put resistors in place of the knock sensors. I also don't think it really has anything to do with how much boost I'm running because it is acting up at idle and when the car doesn't have boost. I'm thinking the ecu may be bad. The person I bought the swap from let it sit outside for 2 years and the ecu may have gotten wet and screwed something up. I just ordered a Nistune board to use with the z32 ecu. Hopefully that will help correct the problem or make it easier for me to diagnose.
https://www.sau.com.au/forums/topic/397420-rb25-problems/#findComment-6309884
    • Thanks for all the replies fellas. Gonna finish putting it back together and see how it handles the set up. If it starts pinging it’ll be parked.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
