  • Replies 42
I made 260kw at 15psi so never 100% injector duty.
Injector duty is around 88-92%.(depends on AFR)
Does someone want to explain to me how thats possible?
Im making 290rwkw with 500cc and it 77% duty...
going by the above statement I could run E85 on my 500cc injectors and get more power... wtf...
PLEASE don't! :P
please do!
it's not possible under normal circumstances. unless your running wmi or something similar anything more than ~200rwkw on standard injectors is either running lean or is just a happy dyno.
please do!
Happy by 60 rwkw?
Standard injectors are 370cc, which i've been told makes them good for 370 crank HP at 100% duty and standard pressure, or there abouts? So in theory, the 400-450 crank HP Toshi is making would need %15-%25 more pressure to keep them below %90 duty?
Is that right, or am I missing something? Also interested in this.
Defently not the dyno, it reads within 3kw of factory spec on new cars that have been run up, maybe ive just got a freak 25? oh btw my vvt isnt connected =/ but that only affects mid =)
Edited by 51NNA
correct its also a dyno dynamics, my tune was done at 11pm on a winters night so it was getting nice freezing air, doubt it would make the same power in summer.
Edited by 51NNA
no...were did you get that idea from? LOL there is a setting that shows flywheel power but its defently RWKW, i dont understand why you think its so hard for a rb25 too make 200rwkw, my rb20 stock on 1bar was making 180RWKW...
Edited by 51NNA
Youll find most will say HP and RWHP these days, the tests were done on stock WRX's, when i worked there we mainly did wrx's because of the AWD dyno..and most of the time people would complain our dyno showed a low reading compared too others.
Edited by 51NNA
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
