So currently putting a list together on what mods ile be doing to my 25, have a 8g budget im working with too achieve close too 400hp and build my 32 into a drifter, will never be rego'ed again.
currently im going with
definite mods
HyperGear G3 turbo
DW300 in-tank fuel pump
740cc Deatschwerks injectors
Maybe mods
EWP
6boost midmount
Greddy manifold
But im stuck deciding if i should go with E85 or a WMI setup, both have there pros and cons, for me E85 is harder too buy as im in queensland but the power gains and and anti det will be alot more then WMI, but WMI will bring my temps down, engine will run alot cleaner and is easy to get...or run 50/50 E85 and 98ron...hummm
any advice will be appreciated,
Thanks in advance!
Edited by 51NNA
https://www.sau.com.au/forums/topic/397600-wmi-or-e85-stuck-on-a-choice/
you can easily run WMI on E85, but now your talking some serious power lol more than you will push from a G3
for a track dedicated car in a non E85 friendly area, WMI will be easier to make do with.
once E85 is easier to come by you wont be at too much of a loss to retune and on sell the WMI kit. The WMI kits are under $500 for something that will do the job.
Why is E85 hard to get for a track only car in brisbane? There's a caltex at goodna which sells it, you'd go past that on the way to QR. There's also one in ipswich itself, a few over on the bayside and one near mt gravatt.
WMI is a BC E85 or agrestic Oz [where E85 is unavailable] solution. If you have good access to E85 and never travel outside the metro area/s then use it - its cheaper and easier to set up than WMI. For all us erudites unable to take advantage of E85, WMI is the answer.
I think the question that determines which way you go is how often do you drive the car. A lot of k's will mean WMI.
I'd like to see someone try a little straight water with E85. You would spray 1/2 the volume that you would if using a WMI setup for the same power level. Around 400cc for 400kw atw.
The advantage I see is that you could run the E85 tune a lot leaner, into the 12.x:1 range. Which will help a little with fuel economy in the long run. I can't remember exactly, what he told me but Piggaz's car drinks E85 at a pretty alarming rate. Well over 10lt/minute at wide open throttle.
From what I understand about E85 tuning, rich AFR's under full load are needed to help keep detonation at bay and also to keep things from getting too hot. In this way E85 tunes more similar to pure methanol burning engines than ULP.
Im running a Microtech LT12s btw, its going to be a track car so distance isnt that much of an issue, you use around 45% more fuel when your on E85 because to get the same amount of energy from the fuel you require alot more, just like Avgas, i just dont want to have to bring 100LTs of E85 too every drift event lol
Can someone explain how you'd do the 50/50 ethanol mix, does this mean mixing fuel at home from a drum or would you have 2pumps at the servo, one for 98 and one for ethanol?
What kind of gains would you get from 50% mix if your making say 300kw with 98?
id say get 2 20lt drums and put both in your fuel tank, i wouldnt buy e85 from the pump, only the drums, i assume it would be simlar gains too straight E85 but not as much, would also require less fuel then straight E85
just go flex-fuel setup.
Ethanol content sensor
ECU with digital input (Link G4, some of the Haltechs etc)
And get some ID1000's at least, to leave you some headroom if you change your mind. Better injectors anyway.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
