Took a few pics of the clutch last night
Flywheel
One of the plates
Cover
Done ATLEST 250 7000 RPM + launches. Feels the same as the day I took ownership of the car. It's going straight back in. Very very surprised at the condition of the plates.
Another reason why i am so happy i spent the money on one of these clutches comp spec ftw
Paul, good to see that u stuck with the 2.8. The 3ltr will ruin your gtr due to the mods required with cutting and drilling and stuffing around, you have such a nice example r33...if your car was clapped out then I'd say go to a 3ltr.
Unfortunately when u get the horsepower bug, things break (as per Ian's comment earlier).
Im not a big fan of polished ports.
Heated Air = increased viscosity = extra drag through a smooth port. this has been proven.
I have had my Rb26 head flowed to its maximum ablity without any polishing
Yes it has!
When you look at the list of high powered engines this guy has developed in the last 15 years in Japan from the Drag33 to time attack engines down to current GTR35, you know he has got a little bit of knowledge of what he's doing, plus he's got the runs on the board having built literally 100's of race engines and high performance cars.
End of the day its the complete package that makes everything come together to give a car that has buckets of torque, great power delivery on low boost and isnt going to go bang.
Also you might want to have a real good look at a few other top Japanese engine builders like Jun etc and see what they do.
Are they doing it or have they done it wrong ??
These guys were pushing the boundries of the RB before most owners here were out of wetting their beds.
Its easy to say yes this is proven and thats proven but how many of you guys have built engines and own cars like these guys in Japan have built and still do.
Have you guys actually been and seen what the Jap top tuners build ???
For example in Australia how many 9 sec cars are there..Japan 10 years ago they were being pumped out left right and centre.
Nowdays hardly any and thats due to economic differences e.g Japan is going down the tube big time so nobody has the coin anymore.
Sadly the RB in Japan today is a dinasaur, alike to the old golden Holden 308 , yes parts are still available and the odd build still happens but this is due to just being for bread and butter money. The focus now and the in future is well and truly the GTR35.
At the end of the day you have to look at what Pauls building here. This is not a knuckledragger engine, its being built for all round high performance and high response so he can take it out to the circuit and go very quick but still enjoy a Sunday drive but have all sorts of anger under the loud pedal.
He might have a little bit of knowledge but if those inlet ports are polished (which they kind of look like they are) there are deficiencies in how that inlet port will perform... that is the bottom line, it is FACT! Whether he has built 10 engines or 100 means nothing. Plus the fact that this head also has +1.5mm inlet valves is a whole other issue...
I don't think it is right to continue this on Piggaz's thread, apologies mate. Marcus send me a PM or email if you like.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
