wow! looks like a gain of 50kw @ 4krpm!
must be happy & must be hanging to drive it
so with the gtrs's u were making 200kw @ 4krpm & now you are making ~340kw with -5s & latest setup :)
what is the difference in the run with the blue line v's the brown line (in the 1st graph) or is it just 2 runs where you were trying to diagnose the miss?
Yeah man.... We pumped more boost into it to see if it did it... which it did.
It'll be nice to have 350 at 4000 RPM. I'm sure with a bit of fiddling we will get there :D
i wonder how your numbers would compare to a larger capacity v8 (i.e. 6.2ltr, ls3) which makes the same peak power...would be interesting to see if your 2.8ltr makes more power & torque @ 4krpm
Im waiting on your final figures dammit ...so i can copy the specs ;)
You may want to get the more aggresive ones :P. Your turbos are slightly bigger also.... Bump up that comp ratio!!!!
I wonder that also. Considering a current "HSV" commo makes what, 325 KW at the flywheel at its peak? (Correct me if i'm wrong). I'm sure in the lower part of the rev range (1000 - 3000 RPM) the V8 would feel more grunty.... after that.... who knows.
Lets see if you can match my old typhoon of 1,000nm at the treads :) and i wouldn't worry about the hsv v8 I'd be trying to match/beat the new ford one! I havent driven one but all I keep getting told is that they are insane
Lol. But I'm only 2.8 without a 3 metre stroke length!!!
They left it at 30psi, a good even number :)
Video doesn't do it justice. It is the cleanest 33 GTR I have ever seen. Everything about the car is immaculate, you could eat your dinner off the engine lol
    • I was getting anxious with the DVLA not knowing if the paperwork is fine or not, so I rang them. No update had been given, but I  was reassured that providing the box was ticked on the V750 then the application will go through fine. I've been checking the DVLA website pretty much every day, in the hope that it would have been done. Fast forward to Monday 29th  and I was greeted with a new screen on the check, and it finally showed as Taxed and MOT'd, woohoo! The car was in desperate need of a clean, not knowing when this day was coming it was put off. As far as I was concerned I had another 3 weeks  I'm not normally one for using snow foam, but I wanted to give it another try It hasn't cleaned up too bad considering it's 21 years old and lived on a boat for a number of weeks. The personalised number plate is J2 XBK, an illegally spaced number plate would have it read J2X BK. BK could either represent  the colour black or Baker, which is my surname. I filmed the first drive, the Youtube link will be at the end. I used the same driving route I did with the 323F V6 when I had a new exhaust installed, heres a couple of photos A few more since then Youtube video can be viewed here: https://www.youtube.com/watch?v=TjkFHPzjGDw
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
