you should try and get the nismo air cleaner for your car (although I think you may need nismo intake pipe to match :O)
Besides that the engine bay is really nice (I like the nismo plenum)
Edited by Ants
I like my $10 paper job haha!!!
Nah, bugger that pipe. So expensive.
Ill get another photo this week with all the covers on. Looks so much more complete!
Hey Paulie,
Next time you have the snorkle off can you take a pic and send it to me? I've been meaning for ages to put the stock airbox back in and delete my Pods. But like you I don't have AFM's anymore.
Thanks.
Out of interest, I appreciate that no two engines are alike but any thoughts on the Tomei 2.8L kit vs Step 0 or Step 1 HKS Kits?
Depends on what the cars going to be used for really, I am using the HKS Step Zero in mine and it's all good so far
One for Robbo. :)
DFE492DD-7696-4879-9F78-EE90BA9AF704-325
This one is an interesting one. This is my first ever tune with the GT RS's about 4 years ago and this current setup. I'm making the RS "peak torque" numbers at the end of my graph now.
273BB74F-61E7-4801-A5CC-8D15A53B52AF-325
Thanks mate :)
Was out there today obviously. Yavuz was doing the light/medium load stuff. One of two more bulldog power runs then the they will work there way down through the petrol blends.
Question. For those of you who have removed the standard heat exhcanger, what did you do with the oil temp sensor? Pressure is sweet as we can put them into the sammich plate.
my temp sensor goes into the 2nd bung on my sammich plate as I has no heat exchanger crap
I'm having a pressure sensor back to the ECU, so that will be off that port you put your temp into.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
