Fkn Marko! Haha
18 x 10 + 12 they are. I should have taken a photo of them. They look pretty fat. I think they would sit a tad better on a 10.5 inch rim but meh.
Just hurry up farken. I wanna drive the arse off
It!!!
Box is built, it ain't very often you hear of rear diffs busting, front diff.... I hope not hahah.
You do in GTST, just ask Dave :ph34r:
Haha cant wait to see the results :thumbsup:
In my mouth!
Ohhhhhhh dear!
Have you converted to the dark side Paul.
On a serious note what fuel setup are you currently running on the car i.e. surge tank, fuel pump etc...???
Ohhhhhhh dear!
044 intank lifting to a 5 litre surge tank which sits under the boot. Then two 044's which have just been staged feeding the engine. Two 23 Micron filters before the engine and checkvalves on each pump. -6 lines to each side of the fuel rail, -8 out to turbosmart "FPR 2000" fuel reg.
Yavuz has also set up fuel temp correction (measured by the ethanol content sensor). A fuel cooler with ducting will be added in the near future.
