are the v-spec and non v-spec diffs the same width ?, I thought not cause I was expecting to change the CVs as well but I could be wrong
Some guys you need shafts, others say you don't. I'm a little confused myself.
When I get the housing and diff centre (this week hopefully) ill take it to Award and plonk it on the table.
I think my battery is 450 crank amps or something like that pffft.
If u run a trickle charger, the battery should give u 5yrs of life...I think my charger was $50 from bunnings.
I also have a battery charger if yours just needs a refresh :)
I have an Odyssey super dooper, suck me off piece of garbage in there at the moment. I ALWAYS have it on trickle when it's at home. I accidentally let it go flat when I was waiting for the engine. That was it, been a bucket ever since. Have it on charge all night at Unigroup and it won't even turn the car over hahha.
I'd just get a generic battery for ~$100
How much is an odyssey?
I will this time. Ummm alot more than that!!!! I've already taken it back once... So ill be taking it back and expressing my disappointment that's for sure!
A place in Smeaton Grange ( Nerellan), was $350 and it is physically smaller then the factory 32 battery, it's actually a motor bike battery
How long have you had it?
Ill give you a buzz tomorrow. I'm drunk.
I have killed a few batteries over the years. Last one I called the NRMA, bloke installed the biggest battery he could fit in the space and even put new grounds on it for $160.
You live in the city, your parts are a 5 min drive, I live in 1942, they have never seen a Japanese car up in these parts! Now skids for kids ya phag!
ill sort it tomorrow ya homo!
    • If you mean the alarm immobiliser; theyre internal to the alarm itself which makes that difficult; I couldnt even see where he put it; its not in the same place as last time; but with all black wiring it might be very challenging to trace  I had someone turn the key for me as I know it only primes for a couple of seconds As my post above; I am getting no voltage to the pump at all; but I am testing continuity of the power line (SB) from the pump plug to the relay fine. As well as the negative from the pump plug to a 12V constant.    Yeah; he blammed the no start on a bad battery; said I needed to get a new battery and it'll start. Turns out the battery drained because the tail lights had been on for half the day during the install (the rubber cushion on the brake switch gave out while he was testing it as I have a picture of the car from that morning with the tail lights off..i've replaced that). The battery was turning over the engine just fine for a long time; but got low since lights were draining it so it was too low to test a start after he finished. I bought a new one on his advice...$250 wasted. My original battery charged up just fine and is healthy.    It was running perfectly fine when I messed up the old alarm (programmed out the remotes). He couldnt start it after removing the old alarm; my assumption is that when he unhooked it; he didnt bridge the circuit back when trying to start it. Its always been perfectly fine. The ECU swap and pump were 2 years ago. It's never missed a beat in that time.
    • This is a big issue for me without the diff. I just have zero drive from the passenger side when drivers side has no traction. Bec's parents place has a crazy steep driveway with odd camber and I have never been able to get up. My bro-in-law's 130i with an (unknown brand) LSD gets up fine as does their dad's Hiace. My car stays at the bottom. We have other odd camber roads around here as we're elevated a bit and if it's raining I can get totally stuck around some hairpins.
    • Yeah, I am super excited for this.
    • Was the car running before he touched the car?
