Lol. Here we go. Whore thread ahoy!
Sorry, didnt mean to start anything, was the first thing that came to my mind. Must get out of the gutter lol.
Out of curiosity, how do you expect the new dampers to compare to something like the ohlins flag r's?
Haha. I don't care mate. Whore away :D
Well, I ain't spending all this money for nothing ;).
What I have in there ATM is basically a flag R, just with a Nismo sticker on it. On the canister you see "Ohlins" written on the canister. Time will tell.
If you dont mind me asking, how much are they charging to do the setup for you? PM me if you like.
Just interested as ive been looking at flag r's or r tunes for my 32R, but if these are just as good or better at a fraction of the cost, it may also be a viable option for me as well.
Staying with remote reservoir?
Me reservoir. The body of the shock is a bilstien PSS9 with Dejan's specs.
My set won't be able to be put into a R32. Totally different suspension setup. How much are you looking at spending? These definately are not "budget" but they're not $10,000 either.
Ill pm you more info.
Yeah, judging by your comments i assumed you used to have (well still have for now) nismo r-tunes, which have a remote reservoir.
I know that R32 and R33 GTR's have a different setup, different weight and geometry, which is why yours would be no good for a 32.
"Budget" is not what im after, and yours is sounding like a good option.
Yeah, please PM me some info if you could, im quite intrigued.
  • Like 1
PM's flicked fellas!
Suspension has been put back till the 31st of July. My box of Ikeya bits still hasn't turned up from Japan.... GRRR!
Yea i think i saw that box at the airport when i was working... :ninja:
Dont know where it could of gone... :whistling:
hahaha
Out of interest is it only the nismo r tune coilovers that have the remote reservoir or do the s tunes as well? Reason I ask is I have some sort of nismo suspension in my 34 at the moment and it has a remote reservoir just not sure exactly what it is
So Nick, it turns out you didn't steal my box of gold parts :D. Roll centre adjuster kit and tie rod ends here. That pretty much completes the underneath of the car. I think the only rubber/plastic bush mount on the car is gearbox mounts and engine mounts. ALL the arms are pillow ball and rear diff bushes are alloy.
F3F6AFC0-90C7-41CF-90E2-17D8D94E27F5-350
Dampers should be at Unigroup by now. Booked in for the 31st.
I think thats the box I threw down the stairs cause it had ur name on it :P
cya on the 31st
Haha. Not sure if it would have made any difference. These things are heavy/solid as hell!
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
