Nick is going for a ride in Paul's car on Tuesday and will see the stroker engine is miles ahead in every way of the standard capacity engine
very lucky for Nick. However, stating that every other non-stroked 26 engine owners is shit is not cool bro.
And when your done you can post in this thread telling everyone how much better the stroker engine is compared to the piece of shit 2.6L
http://www.skylinesaustralia.com/forums/topic/433110-to-3026-or-keep-the-26/page-6#entry7077790
you said this mate^^^
hence stating all 2,6 engines are shit.
I like my engine lol couldn't afford the stroker :(
Pads are ordered. PAGID RS19's, fronts only. These things better put my head through the window!!! Not farken cheap!
TBH Paulie I can't see anything being cheap with regards to your brake setup and suspension
Well, true. But $400 plus for a set of front pads. Taking the piss a bit!!!!
I agree with you mate. But those pads are designed for endurance and sprint racing so I'm not surprised that they cost so much.
PAGID RS19 are high quality performance pads. They will certainly do the job on track.
mate, as discussed - you'll also find they look after rotors nicely. Figure that into your cost calcs. If you put in a $200 pad that chews out rotors - what's the real cost then?
Also don't be surprised if they don't have quite the initial bite that you're used to. But, they'll be consistent right through the temp range. Trust me they are good.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
