I think Piggaz is pulling our leg.....
There's no way he'd pull the pin on this LOL
but then again...
'most people give up just before the finish line' :(
Not pulling anyone's leg mate.
If I put the new box in ill never pull it down. It won't be the last GTR I own, put it that way.
Return to stock, sell the car. All the goodies bolt right onto the later model.
Engine is up for sale if I get offered the right price.
  • Like 1
U can get it in red as I've seen a few around...then u can get RANGA plates!!! That would be fitting
Oh piss off, wog. You should get some lamb horns and cable tie them on the front of the ADM.
  • Like 1
Do like i said man, get 34 and do direct swapage, good shit onto 34, 34 shit on to 33, 33 with 34 shit is worth more then 33 with 33 shit
And dont start whinging about space, i am working on something ATM that will mean i will have the space needed and some
Get OS88, get it into 33 and enjoy till 34 rocks up then swapski
  • Like 1
And engine, box and few suspension arms ain't the end of the world.
That and I can sit on the coin for a while and wait for a car that I want comes up.
Who knows how long that will take.
just buy a an R35 already Paul
  • Like 1
If you do do a swap of the running gear to an R34, then for the love of god pay someone to do it so its not parked in a garage for 6 more months. Passion is lost when too much time passes by.
  • Like 1
As long as you own a GTR, you will be happy. I should have kept my air horns from my gemini back in the 90s...the chicks luved them.
Get a dato 1600 with your running gear, baby GTR - make sure it's red
Edited by Marko R1
Why keep stuffen around, piss the White Whale off and get an EVO, save you a fortune :)
Not all bad I will give you $7k for your OS88, this price is based on the fact that by the time you get it, it will be obsolete :/
Pete, no EVO's. As much as I hate to admit, they're a much faster car, but they do miss a little something that a big fat R has.
An OS 88 and and BIG straight 6 won't exactly fit either ;)
  • Like 1
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
