I think Piggaz is pulling our leg.....
There's no way he'd pull the pin on this LOL
but then again...
'most people give up just before the finish line' :(
Not pulling anyone's leg mate.
If I put the new box in ill never pull it down. It won't be the last GTR I own, put it that way.
Return to stock, sell the car. All the goodies bolt right onto the later model.
Engine is up for sale if I get offered the right price.
  • Like 1
U can get it in red as I've seen a few around...then u can get RANGA plates!!! That would be fitting
Oh piss off, wog. You should get some lamb horns and cable tie them on the front of the ADM.
  • Like 1
Do like i said man, get 34 and do direct swapage, good shit onto 34, 34 shit on to 33, 33 with 34 shit is worth more then 33 with 33 shit
And dont start whinging about space, i am working on something ATM that will mean i will have the space needed and some
Get OS88, get it into 33 and enjoy till 34 rocks up then swapski
  • Like 1
And engine, box and few suspension arms ain't the end of the world.
That and I can sit on the coin for a while and wait for a car that I want comes up.
Who knows how long that will take.
just buy a an R35 already Paul
  • Like 1
If you do do a swap of the running gear to an R34, then for the love of god pay someone to do it so its not parked in a garage for 6 more months. Passion is lost when too much time passes by.
  • Like 1
As long as you own a GTR, you will be happy. I should have kept my air horns from my gemini back in the 90s...the chicks luved them.
Get a dato 1600 with your running gear, baby GTR - make sure it's red
Edited by Marko R1
Why keep stuffen around, piss the White Whale off and get an EVO, save you a fortune :)
Not all bad I will give you $7k for your OS88, this price is based on the fact that by the time you get it, it will be obsolete :/
Pete, no EVO's. As much as I hate to admit, they're a much faster car, but they do miss a little something that a big fat R has.
An OS 88 and and BIG straight 6 won't exactly fit either ;)
  • Like 1
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
