  • Replies 179
I managed back to back 12.35 passes with 40hp less and 19inch rims with streched 245 rubber. Going back with more power over the entire rev range and 18s with much better 265s, so i am confident of high to mid 11 second passes.
How did you go with traction with the 19's?
I run the same tyre with less power approx 270awkw and had wheel spin all thru 1st gear....rs4s
car was to low as well, too much neg camber as well
My setup was similar at the time around 270kW, 3ish deg neg camber and impractically low. I let a heap of air out and traction was pretty touchy, my first run was all wheel spin and limiter bashing.
I got my best times with 6500ish RPM launches and plenty of clutch slip to keep wheel spin to a minimum.
Edited by numleg
In reply Rudi, I still have no front shafts in the car atm- its RWD. I want to get it back on the dyno, so I really cbf getting it in and out just to do some drags.
Plus I think that Craig and I are going on the same night for the lolz. Craig needs a tune first. He wants to stick it up the Mexicans.
I love how you rounded it off to just me Alex! ;p
Need to practice my stall launches.....20psi and 4wd for the win! :P
I may be able to get the same response now, the .82 on the new GTX3076 is in and it feels much better than the old 1.06. :)
Boost at stall would be nice... :)
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
