i wasnt mouthing off i was voicing my opinion. i havent seen a hugos built transmission so i dont know what they modify inside to make them hold together. im speaking from experience from WHAT I HAVE SEEN not from what other people do.
  • Replies 74
Well the whole "trimatic is a piece of shit" comment isn't really voicing your opinion, it's making a judgement on a topic that you're not really qualified to express an opinion on. A more suitable comment would be "i havent had much experience with this gearbox"
  • 2 months later...
you havent seen enough then, your ass hole will blow before a built trimatic does! :D
Hey guys, i'm gonna give first hand experience here on trimatics.
I have a R31 with rb30det putting about 270rwkw. I'm currently on my second trimatic and at this point in time might be third soon.
I read this thread as i was looking for something better that can handle the power. Not that saying 270awkw is heaps, but i don't feel the trimatic is up to the task.
The first box i only made 190rwkw before i smashed the planetars/gearset. Dunno how just did, so seeing how i had the setup i got a hugo's box. Yep felt the same as the first one, no probs, but only 2000k's old and i have lost first gear, so its in the shop again getting rebuilt. Its giving me the shits as the bellhousing is so big that it is extremely difficult to remove. the trans tunnels in the skylines aren't big enough to start with and even though i have "massaged" the firewall still having issues..
Hugo only rates the trimatic at only 450hp, well taken into account the power losses through the drive train it is estimated that i have around 450-500hp at the crank. so i can't really think of any more power upgrades that i would like to do atm.
I had a chat to Mike at MV autos, he sugested the standard 4speed auto same as in the r33gtst(i think) and rebuild that up. he said he can build them to take up to 1000hp. The internal gearset is stronger than the trimatic and even jatco.
So that might be the next plan of attack as i'm looking to top 350rwkw in the future and crack 10's
Edited by Dj laBBy
The std r33 gtst gearbox is a JATCO so how can it be stronger than one? ;)
It's a great option for what you're talking about though.
I think he is refering to the Re4r01a skyline style jatco being much stronger than the older 4n71b style jatco. These days there are a lot of parts available for the later skyline style autos and can be built to handle 1000hp with full manual valve bodies,transbrakes,billet servos,wider band,stronger clutches and steels and a decent reverse clutch pack to live with the transbrake and i believe there are some t400 splined hituff input shafts on there way for those who break the standard ones that have been heat treated. The planetarys also need to be heat treated. If this box isnt strong enough then jatco also make the Re4r03a which is even stronger from what ive been told with larger shafts etc and all the manual valve bodies etc are also available for these. These were used behind the vg30dett and vq30det and also in some patrols in 4wd form that could be suitable for a awd gtr. The only real problem i see with the transbrake setup is that its only really suitable for drag racing as it has no compression braking but it is also available without the transbrake which would be suitable for the street and with a well setup converter should still launch fairly hard at the track.
So who builds these boxes??
Yah i was talking about the Re4 box. I have heard that the VG30dett boxes were pretty tough, might look into that.
How would they put in a t400 input shaft?? i guess the converter would have to be completely custom coz of that.
Kewl thanks for t he info.
the 03A is also in the 4 speed patrols very good boxes. 01A's are in older model patrols and terranos also a good box. anyone who actually likes building gearboxes and actually cares can build them. the business i work for here in WA deal with KEAS and we make quite a few strong boxes up for race cars
Hey guys thanks for all the info.
I ended up chatting to wollongong autos and looking at building the VL jatco 4speed. Its not as strong as the 3 speed, but will do the job.
Ended up opting out of the Re401 box. Just coz its not as proven with some places and others like bms that build them are looking at over 4k for a box.
Thats just a little too much for me atm. Plus wollongong autos just down the road, so he can fix me up if need be, not keep sending boxes interstate.
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
